+ Reply to Thread
Results 1 to 12 of 12
Thread: What resistor???
  1. #1
    ANTlabs Bad
    Join Date
    Oct 2009
    Location
    Florida
    Posts
    31
    Post What resistor???
    A simpol question. how do you drop 4.5 v to 3.5 v. I eed the answer bytomarow at 11:00 AM.
    Thank you
    Please visit ANTlabs at: http://www.robotjunk.webs.com
  2. #2
    birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    How much current, that's what were need to solve this Or what is the resistance of the load?
    Mike
    My website: www.ElectroBird.net
  3. #3
    ANTlabs Bad
    Join Date
    Oct 2009
    Location
    Florida
    Posts
    31
    It is the 15 LED circuit again. your suggestion was 4.5 volts (AA battery).
  4. #4
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    Ah so your LEDs are 3.5 V.... well (4.5V-3.5V)/20mA = 50 ohm resistor. You will need 15 because there are 15 leds in parallel. Understand ?
    Mike
  5. #5
    ANTlabs Bad
    Join Date
    Oct 2009
    Location
    Florida
    Posts
    31
    Wait, first of all, I want them in series. Will I rally need 15 50 ohm resistors if thy are in parallel
  6. #6
    ANTlabs Bad
    Join Date
    Oct 2009
    Location
    Florida
    Posts
    31
    Also, I only really want to use 1 resistor.
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,864
    The resistor in series with an LED limits the current, it does not drop the voltage. An LED has its own voltage and could be powered from thousands of volts if the current-limiting resistor is calculated correctly.
    If you connect fifteen 3.5V LEDs in series then you need 15 x 3.5= 52.5V (or more) for them plus about 5V for the single current-limiting resistor.
    I don't think you have 57.5V or more.
    Why did you make this new thread? It has no circuit description and no schematic so we don't know what you are talking about.
  8. #8
    ANTlabs Bad
    Join Date
    Oct 2009
    Location
    Florida
    Posts
    31
    Question
    I need to know how to power a white LED on 4.5 volts. hat resistor should I use. As simple as that.
  9. #9
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    185
    see if this link helps. It's worth bookmarking. LED series parallel array wizard
  10. #10
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    I know what you are trying to say but this is entirely incorrect:
  11. #11
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    Perhaps the modification should be "it does not drop all the voltage"
    Mike
  12. #12
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,864
    A white LED can have its current limited by a single resistor from a supply of 4.5V if you know the voltage of the LED (it is a range of voltages from 3.2V to 3.6V) and how much current you want in it.
    Since you did not say what is the max allowed current in the LED, the amount of current you want in it or the voltage of the LED then we cannot help you simply calculate the value of the current-limiting resistor.
+ Reply to Thread
  1. resistor ?
    By wjyates in forum General Electronics Chat
    Latest: 21st February 2009, 11:40 AM
  2. resistor help
    By cantfindausername in forum General Electronics Chat
    Latest: 24th February 2008, 11:06 AM
  3. Datasheet 330K 1/4W Resistor and 100R 1/4W resistor
    By kid in forum Datasheet/Parts Requests
    Latest: 17th February 2006, 02:55 PM
  4. Resistor help please??
    By madmikejt12 in forum General Electronics Chat
    Latest: 4th October 2005, 03:06 PM
  5. Flashing LEDs - resistor or not resistor?
    By grrr_arrghh in forum General Electronics Chat
    Latest: 19th March 2003, 07:23 PM
Tags for this Thread
