Hi all, Nice forum! It has been many, many years since I did any electronic experimentation so please be gentle ![]() I am developing a LED light test model. At this stage I am creating a test unit using a TI TPS61042 constant current LED driver. A smaller .pdf of the LED driver is attached. I believe Figure 24 on Page 11 is want I want to start with however I will only be using 5 LED's, if that makes a difference. I want to add a variable brightness control to go from 0 to 100%. Such as a rheostat. The diagram indicates I can do this via a PWM circuit to the CTRL pin. There is much more info on Pg.2 under the CTRL section. I have been looking at dozens of PWM variations and now I am more confused. Can anyone assist with a simple PWM I can add into this circuit? Thx DD | |
You can try this simple circuit. R1 and R3 model a variable resistor, with the junction of the two model resistors being the wiper connection. The variable resistor controlls the duty cycle. Connect the "OUTPUT" wire to your chip.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
| | #3 | |
Thx DD | ||
Correct. The middle connection is the pot's wiper connection.
| adding, circuit, pwm, simple |
| adding "no link" alert for RLP434 circuit | guy2009 | Electronic Projects Design/Ideas/Reviews | 0 | 4th July 2009 03:19 PM |
| adding noise source to a circuit | mpradhan1 | General Electronics Chat | 12 | 9th February 2009 02:16 PM |
| Adding a component to a simple 2n7000 circuit | mabauti | Electronic Projects Design/Ideas/Reviews | 5 | 21st September 2008 12:02 AM |
| Adding 30A Current Limiter to Low Volt-High Curret circuit | Scopemaster | General Electronics Chat | 9 | 2nd November 2005 06:50 PM |
| CIRCUIT FOR ADDING GAIN TO AN AMPLIFIER | timothy | Electronic Projects Design/Ideas/Reviews | 1 | 3rd November 2003 03:19 AM |
