Old 19th October 2009, 06:12 PM   #1
Question Bcd 7447, bi/rbo ,lt , bi
I'm trying to build the 7447 BCD from its
schematic, but I don't understand what to do with the BI/RBO, RBI, LT
inputs. I tried grounding them to no success. HELP!
When I plug a ground into those inputs the light blinks. I'm just starting to learn about datasheets so I haven't a clue on how to read the one from ti.
http://focus.ti.com/lit/ds/symlink/sn74ls47.pdf
D3422 is offline
Old 19th October 2009, 06:18 PM   #2
RBI is used if you don't want it to count from zero. Otherwise it must be +5V or open (no connection)
BI must always be +5V.
LT is lamp test and must also be +5v.
I got that info from the truth tables. +5V = high (H), Ground = low (L).
technogeek is offline
Old 19th October 2009, 06:18 PM   #3
Look at this forum link, especially the picture posted.
Displaying Gibberish
Bcd 7447, bi/rbo ,lt , bi-aaesp10.gif
ericgibbs is offline
Old 20th October 2009, 10:18 PM   #4
Thanks alot, It really helps. My number shows on the LED but it flickers to 8, says If I have a 2, f and c will flicker on and off, if I have 0, g will flicker. Its driving me mad, I checked my and triple checked my connections they're all fine.
D3422 is offline
Old 21st October 2009, 07:36 AM   #5
if i may ask also the operating voltage of the IC that the OP posted earlier, or the 7448 kind and also the 74390 used in conjunction with it?
data sheet was not very helpful to me.. it just says VCC.
it could be 12 or 5 volts for all i know.
thanks alot guys and the OP.
wejos is offline
Old 21st October 2009, 07:43 AM   #6
The early 74xxxx series is TTL +V is normally +5V.
Bcd 7447, bi/rbo ,lt , bi-aaesp02.gif
Old 21st October 2009, 07:47 AM   #7
okay eric thanks for your help.
ive been playing with them in a simulator it ran OK with 12v but i guess i'll have to take your word for it, you\re the expert here. i was scared to try it in-circuit before this lol.
wejos is offline
Old 21st October 2009, 07:53 AM   #8
hi wejos,
This is one the 'pitfalls' with some sims, they are only a tool and the results should be verified with an actual circuit.
As they say, ' if all else fails, read the datasheet'...
Old 21st October 2009, 11:53 AM   #9
Default Question what is X1, X2 and X5
from what little I know, pullup resistors are supposed to be used? or in this case pull down?
always thought HIGH was at or near Vcc.
look it up
MrDEB is online now
Old 22nd October 2009, 03:21 AM   #10
Its working now. I had to change the current on the led.
D3422 is offline
Old 22nd October 2009, 03:22 AM   #11
Thanks everyone. I'm going to work on building a digital clock and post it on my wall.
D3422 is offline
Old 23rd October 2009, 05:55 AM   #12
Originally Posted by ericgibbs View Post
hi wejos,
ill try bear that in mind eric, datasheets always come handy, glad people round here help decipher the voodoo content lol
very interesting stuff thuo, i mean electronics
thank you
thank you for this post OP also
tumbling down the rabbit hole again
wejos is offline
7447, bcd, bi or rbo
Interrupt on RBO pic16f628a birdman0_o General Electronics Chat 1 14th May 2009 04:14 PM
7447 to 7-segment 1111 Electronic Projects Design/Ideas/Reviews 5 5th October 2008 12:56 PM
The Circuit Like 7447 phu hung Electronic Projects Design/Ideas/Reviews 4 14th September 2007 11:13 AM
7447 bcd kelangfei General Electronics Chat 2 15th June 2007 10:31 AM
7447 with resistors Overclocked General Electronics Chat 5 27th January 2007 01:30 PM
