Old 20th October 2009, 02:06 PM   #46
oh and when i simulate conditions R2 less than R1 (without amp stab.) thus making the gain less then 3 where oscillations are supposed to attenuate to nothing..i get a small amount of signals at the beginning in the microvolt range before the signal completely becomes a flat 0...are those micro signals due to noise in the circuit?
qtommer is offline
Old 20th October 2009, 02:11 PM   #47
You should use a trimpot to adjust the gain. If the gain is too high then the circuit turns on quickly but the distortion from the diodes will be high.
If the gain is too low then the circuit will not start oscillating or the output level will rise slowly.
The amount of gain affects the output level a little.
audioguru is offline
Old 20th October 2009, 03:18 PM   #48
qtommer, look at post #26. That setup should work well. AG's comments about gain of 3 were directed at a different oscillator than yours. It confused me too.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 20th October 2009, 03:50 PM   #49
I am so sorry AudioGuru and BrownOut but im kinda confused now:
Referring to post #26
In this case, when the signal reaches a cetain value, the diodes short out R6, and now the gain is:
1 + (15K + 0/10K) = 2.5. that will stop the signal from growing. In that way, the tops of the signal aren't clipped by hitting the power rail.
so does it mean that after the diode comes into play, the diodes will fully conduct and the shunt resistance is completely shorted out thus leaving the gain below 3?
and once oscillations have started (by setting the gain to higher than 3), the loop gain can then be reduced to even less than 3 and will still continue oscillating?
Therefore, once a signal grows , it is not necessary to keep the loopgain at 1 (gain=3) to maintain oscillations?
qtommer is offline
Old 20th October 2009, 03:54 PM   #50
Almost. The diodes will turn on pretty quickly and reduce the gain by shorting across the resistor. The gain of your oscillator remains at 3 except for at the very peaks of your signals, where it briefly reduces, and then recovers to 3 again once the signal swings low. That way, oscillations are sustaned, but kept of a value that doesn't distort the signal. You have your cake and eat it too
ball.
BrownOut is offline
Old 20th October 2009, 04:24 PM   #51
i see.. so does that mean the gain recovers to 3 when the diodes are off.and when the signal becomes bigger nearing the peaks, the diodes will short out the resistance to lower the gain to ensure that the peaks are not distorted.? so its most of the time a gain of 3 for the wave and less than 3 at the peaks?
if it is most of the time a gain of 3, and the diodes would be mostly OFF unless at the peaks..
shouldnt the total resistance of the voltage divider network should produce a gain of 3? example, R1=5K, R2=5K, R3(SHUNT)=5K (then a gain of above 3 cannot be produced for startup)
im so sorry..im confused...
qtommer is offline
Old 20th October 2009, 04:26 PM   #52
I again refer you to post #26 where all of this has alreay been discussed.
ball.
BrownOut is offline
Old 20th October 2009, 04:55 PM   #53
The gain is always 3. It takes a little time for the oscillations to build up to the clipping value, but it takes a gain of 3 or more to even get the oscillations started. The reason your circuit worked with R3 = 10k, R4= 15K and R6=5K is because the gain equation for your circuit is: 1 + (15K + 0/10K) = 2.5. that will stop the signal from growing. In that way, the tops of the signal aren't clipped by hitting the power rail.
in the above circuit, if the maximum gain that the resistor network can provide is only 3..how does startup for the oscillator occur? ive carefully read the post but im confused..sorry again
qtommer is offline
Old 20th October 2009, 05:03 PM   #54
We've covered that in many posts. What are you still not getting?
ball.
BrownOut is offline
Old 20th October 2009, 07:18 PM   #55
I said to set it wrong.
You must adjust the gain to be slightly more than 3 so oscillation can start and the output rises fairly quickly. Then let the diodes conduct a little at the peaks of the sine-wave which reduces the average gain to exactly 3.0 and holds the output at that level.
Old 21st October 2009, 04:38 PM   #56
to try to understand it better, i did a simulation to compare nodes between X and Y (before and after the diode bridge) refer to attachment.
i noticed that throughout the transient wave, a constant voltage drop is always there (even at the peaks) meaning that the shunt resistance of the diode bridge never shorts..
if the diodes conduct at the peaks, shouldnt the resistor be shorted thus making no voltage drop between nodes X and Y at the peaks? if the diodes are conducting with some "internal" resistance, shouldnt there be at least a change in the voltage drop between nodes X and Y?
qtommer is offline
Old 21st October 2009, 04:45 PM   #57
or is it already from the beginning the voltage drop caused by the diode?
i did another simulation just for a voltage divider resistor network with the values in the previous attachment and noticed the voltage drop is aprrox 3.5V but the voltage drop in the previous simulation is approx 0.5 V
Could that be the reason?
qtommer is offline
Old 21st October 2009, 04:50 PM   #58
You probably won't get much insight trying to measure across the diodes. They will conduct just enough to lower the gain, and only for a short time.
ball.
BrownOut is offline
Old 21st October 2009, 08:31 PM   #59
Diodes do not short in a circuit unless their current is extremely high.
In this oscillator the current in the diodes is very low so when the diode conducts it acts like a fairly high value resistor with a 0.6V voltage drop.
Old 23rd October 2009, 04:40 PM   #60
ic ic...i understand it now..
thank you both for your help=)
for the wien bridge frequency selective network, i input an AC sweep of frequencies in the lab to determine the phase shift response of the circuit. The cutoff frequency of my network based on the values used is approx. 470Hz
From the results, a nice graph was obtained from the frequencies 100Hz to 7kHz..
When the frequency got higher above this point, it seemed that the phase shifts that i obtained from the scope seem to be fluctuating up and down as opposed to readings that should keep decreasing to a negative maximum phase shift..(as opposed to the simulated graph)
Is there any reason for this? i did the measurements thrice to ensure that these fluctuations were not based on my error in reading the scope..
qtommer is offline
bridge, oscillator, wein
Transfer Function of Wein Bridge Oscillator furrycow General Electronics Chat 0 12th January 2008 06:10 PM
Wien-bridge oscillator questions hadoque Datasheet/Parts Requests 64 23rd December 2007 05:41 PM
How does wien-bridge oscillator works?? Hey!to-learn General Electronics Chat 4 7th February 2007 05:21 PM
Wein Bridge Oscillator bananasiong Electronic Projects Design/Ideas/Reviews 45 15th November 2006 10:14 PM
Need help with wien-bridge oscillator headbuttking2 General Electronics Chat 3 27th March 2006 03:33 AM
