I'm currently working on making a simple IR remote just to create the framework for some future projects. I'm using the PIC16F628A and would like to utilize the hardware PWM to free up the processor for other applications. I have the hardware PWM working and according to my scope appears to be outputting ~38.46kHz. I've read a lot of posts on this site and I've seen that Nigel recommends implementing the PWM using software but as I mentioned because of my programming style I would like to continue using the hardware PWM. I'm trying to modulate the carrier signal but most diagrams I've seen use something like th 74HCT132 NAND Schmitt trigger (Simple infrared data communications). I've looked through my stock of parts and I don't appear to have any Schmitt triggered logic devices lying around. I've tried substituting a normal NAND and my signal was all over the place (I expected this but the normal NAND was all I had). My question is, what are my option (While using the hardware PWM) for modulating the carrier signal? I'm trying to avoid placing another order of parts for the time being. I've tried feeding the carrier signal and my data signal back into the PIC but that seems to defeat the purpose of using the hardware PWM. I've been looking for a solution for a few days and I've gotten to the point where I'm going in circles. | |
Why don't you just use the CCP hardware to create bursts of carrier? A simple NPN transistor between the CCP port pin and the LED will switch the LED at a suitable current level.
__________________ Mike ML. | |
So you're recommending just turning the PWM on an off? Do you know if that would affect the response time (is there a lag time to initialize the PWM)?
As always, I still suggest doing it in software, it's easier, and more accurate - what are you wanting to do at the same time as you send data?.
| | #5 | |
Another option is to keep the CCP running, and then use a software timer to generate the bauds. Thought of another one: Use the CCP and dynamically load the pulse width register with the number "zero" or "half period". Zero turns the carrier off, and "half period turns it on"
__________________ Mike ML. Last edited by MikeMl; 12th October 2009 at 06:35 PM. | ||
| | #6 |
The NPN transistor outputting the carrier signal and controlled by the modulating pin seems to be a starting point. I'm not sure how I overlooked that option. I am noticing some distortion in the signal but i can play around with that. When i was writing the basic program I saw a post on the ccsinfo form (CCS :: View topic - Generate 38KHz frequency signal using 16F877A) that described using TMR1 instead of the hardware PWM which was set up the same way as my PWM and they said, given the same oscillator speed, that there would be less than 26 instructions that could be executed in addition to the software PWM code. I'm using the CCS C compiler because I never seem to grasp ASM but i've been programing in C for years. I imagine code written in thes language is less efficient, but until i can wrap my head around ASM i'll have to stick to this. I'm working on a universal remote right now that just combines the few buttons on the for or five remotes i have into a single remote right now, so i probably could use the software PWM but I figured the hardware PWM would give me some more wiggle room in my code.
| | #7 | |
| | #8 |
Just out of curiosity, what makes the hardware PWM less accurate than a software version of the same thing? Is the actual signal less accurate or is it made less accurate by the additional hardware needed. Based on some examples I’ve looked at, both can be implemented in a similar fashion only one directly drives an output while you need to use an interrupt for the other.
| | #9 |
I will not say that the hardware PWM is less accurate but I will say that generating it in software can be much simpler. If you are shy of using assembler and are using the SIRC protocol - Sony - then take a look at SIRC especially the section on the transmitter. It is written in JALv2 but you should be able to convert it to C without too much trouble. Mike
__________________ The "real" world, for all practical purposes, is seldom more than 24 bits wide. | |
| | #10 | |
Next is the accuracy of the series of pulses, in software you send exactly the right number of exact length pulses - using hardware, and turning it ON and OFF commonly produces partial pulses. It's just more work for a poorer result - if there's any reason for it, then fair enough - but when there's no reason whatsoever, why use a more complicated method that isn't as good?. | ||
| | #11 |
Alright, I’ll give it a try. I’ve been going through Myke Predko’s book Programming & Customizing PICmicro Microcontrollers so I’ll see if I can work this project out on the software side. Its been years since I’ve tried any ASM programming so maybe it’ll stick this time.
| | #12 | |
| | #13 |
thanks, i've read through your tutorial once but i'll keep it on hand while i work.
| | #14 | |
dear sir i want to know ASM. [ PIC Tutorials ] is practicaly worked. | ||
| | #15 |
There are plenty of tutorials out there to learn ASM from. Nigel’s site is a good source (has the software and circuits to go with the projects). I’m attaching the source for the IR transmitter I was working on, its pretty simplistic if you want to try and work though it. It was my first project written in ASM in a few years. The programming is probably crude and is defiantly a dumbed down version of Nigel’s IR transmitter but it works. The carrier signal seems to be a fairly precise 38 kHz even when using the 4MHz internal oscillator. My particular remote (for an orion TV) seems to send out a 32 bit packed. I captured the signal from the remotes with a camera and pasted them back together. The two signals labeled Vol up and Vol Down are actually Channel up and down. Guess I was pushing the wrong button while I was capturing the signal and didn't find out till I got the whole thing working and the stations started changing instead of the volume. ![]() Code: #include <p16f628a.inc> __CONFIG _WDT_OFF & _PWRTE_OFF & _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _BOREN_OFF & _LVP_OFF & _DATA_CP_OFF & _CP_OFF cblock 0x20 nCount1 nCount2 nCarrier nData nBits_Data nIDL nIDH nCmdL nCmdH endc Load_Data macro tIDL, tIDH, tCmdL, tCmdH ;Macro to load the working variables with the remotes 32 bit sequence MOVLW tIDL MOVWF nIDL MOVLW tIDH MOVWF nIDH MOVLW tCmdL MOVWF nCmdL MOVLW tCmdH MOVWF nCmdH endm ;Codes for transmission vDevIDL equ b'01100001' vDevIDH equ b'10100000' vPwrL equ b'11110000' vPwrH equ b'00001111' vChUL equ b'01010000' vChUH equ b'10101111' vChDL equ b'11010000' vChDH equ b'00101111' ORG 0x000 goto Main ORG 0x004 goto Main Main: BCF OPTION_REG, 7 ;enable portb internal pull-up resistors BSF STATUS, 5 ;Switch to bank1 MOVLW b'00001110' ;Load W with 0; MOVWF TRISB ;Set everything on PORTB.7-4 to output 3-1 Input, and 0 to output BCF STATUS, 5 ;Switch back to bank0 Start: BCF PORTB, 6 ;Indicator Lights (need to see if there are misfires) BCF PORTB, 5 ;All off unless button pressed BCF PORTB, 4 BTFSS PORTB, 1 CALL SW1 BTFSS PORTB, 2 CALL SW2 BTFSS PORTB, 3 CALL SW3 GOTO Start ;Three buttons SW1 ;Power Button BSF PORTB, 6 BCF PORTB, 5 BCF PORTB, 4 Load_Data vDevIDL, vDevIDH, vPwrL, vPwrH CALL TRANSMIT return SW2 ;Channel up BCF PORTB, 6 BSF PORTB, 5 BCF PORTB, 4 Load_Data vDevIDL, vDevIDH, vChUL, vChUH CALL TRANSMIT return SW3 ;Channel down BCF PORTB, 6 BCF PORTB, 5 BSF PORTB, 4 Load_Data vDevIDL, vDevIDH, vChDL, vChDH CALL TRANSMIT return TRANSMIT MOVWF nData ;Loop 8 times until all 8 bits are sent MOVLW 0x08 MOVWF nBits_Data call SEND_START trans_loop1 RLF nIDL, 1 BTFSC STATUS, C ;Check current bit and send data CALL SEND_1 BTFSS STATUS, C CALL SEND_0 DECFSZ nBits_Data GOTO trans_loop1 MOVLW 0x08 MOVWF nBits_Data trans_loop2 RLF nIDH, 1 BTFSC STATUS, C ;Skip next instruction if C = 0 CALL SEND_1 BTFSS STATUS, C ;Skip next instruction if C = 1 CALL SEND_0 DECFSZ nBits_Data GOTO trans_loop2 MOVLW 0x08 MOVWF nBits_Data trans_loop3 RLF nCmdL, 1 BTFSC STATUS, C CALL SEND_1 BTFSS STATUS, C CALL SEND_0 DECFSZ nBits_Data GOTO trans_loop3 MOVLW 0x08 MOVWF nBits_Data trans_loop4 RLF nCmdH, 1 BTFSC STATUS, C CALL SEND_1 BTFSS STATUS, C CALL SEND_0 DECFSZ nBits_Data GOTO trans_loop4 MOVLW 0x08 MOVWF nBits_Data return ;0 takes 0.6ms -> 600us 600/26 = 23 = 17h ;1 and 0 turn on for 600us each SEND_0 ;Total length 1.2ms MOVLW 0x17 ;600us carrier active CALL ON_38KHZ NOP MOVLW 0x17 ;600us carrier inactive CALL OFF_38KHZ NOP return SEND_1 ;Total length 2.2ms MOVLW 0x17 ;Turn on for 600 us CALL ON_38KHZ NOP MOVLW 0x3D ;Turn off for 1.6ms CALL OFF_38KHZ NOP return SEND_START MOVLW 0xDC ;5.727ms 1 of 2 high CALL ON_38KHZ NOP MOVLW 0xDC ;5.727ms 2 of 2 high CALL ON_38KHZ NOP MOVLW 0xB3 ;4.653ms low CALL OFF_38KHZ NOP return ON_38KHZ ;T = 1/38000 = 0.000026316s -> 0.026315789ms ->26.315789474us MOVWF nCarrier carrier_loop1 BSF PORTB, 0 ;Turn PORTB.0 on about 35% duty cycle GOTO $+1 ;Each GOTO takes 2 cycles (command tells it to move one instruction from current pos $) GOTO $+1 GOTO $+1 GOTO $+1 BCF PORTB, 0 ;Turn PORTB.0 off move this to adjust duty cyle GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 DECFSZ nCarrier, 1 GOTO carrier_loop1 return OFF_38KHZ MOVWF nCarrier carrier_loop2 BCF PORTB, 0 ;Turn PORTB.0 off NOP GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 GOTO $+1 DECFSZ nCarrier, 1 goto carrier_loop2 return END Last edited by evaine23; 24th October 2009 at 01:04 AM. | |
| carrier, modulating, signal |
| Audio modulating.... | things | General Electronics Chat | 6 | 22nd May 2008 03:49 PM |
| ZFF Self-Modulating PWM | skeeterb | Electronic Projects Design/Ideas/Reviews | 23 | 18th May 2008 03:08 AM |
| Modulating Sensors | ahmedragia21 | General Electronics Chat | 3 | 31st July 2007 10:11 PM |
| IR Removal of carrier | mitchjs | General Electronics Chat | 5 | 10th April 2005 11:19 AM |
| MC35i AND NO CARRIER!!! | eduardorrodrigues | Micro Controllers | 0 | 16th February 2005 06:30 PM |
