Old 12th October 2009, 03:01 PM   #1
Default Timing circuit
Hi all,
I am building a remote laser distance finder. I need a timing circuit to find the difference between pulses for 2 photodiodes. One photodiode receives laser impulse right next to the laser. When the 2nd photodiode receives impulse reflected of the distant object. I am looking for time difference between those pulses of about ns. Circuit can output results on oscillator as 2 peaks or any other possible way.
Thanks.
axujiec is offline
Old 12th October 2009, 10:59 PM   #2
You'd need a pretty good timer to measure timings in the order of nanoseconds. It'd most likely be very expensive.
Good riddance, ETO .
giftiger_wunsch is offline
Old 13th October 2009, 05:50 PM   #3
Originally Posted by axujiec View Post
Hi all,
Thanks.
What is the required distance/range of this laser, also the required accuracy.?
ericgibbs is offline
Old 19th October 2009, 04:30 PM   #4
Distance doesn't really matter, I was thinking about 50-300m. Accuracy of about 1-5m.
I was also wondering if its possible to measure distance using pulsating laser and 2 counters connected to nearby and far away photo diode. We would know the frequency of the pulses. 1st counter would count number of pulses and the second counter would time the experiment. For example if its on for a minute there would be certain amount of pulses counted. Since we know the frequency of send pulses it would give a delay.
This would avoid the timing circuit. However if the timing circuit is possible to build it would make the life easier
axujiec is offline
Old 19th October 2009, 04:46 PM   #5
Laser range finders and target illuminators are used in the military who can afford buying that expensive stuff.
To measure distance it is advisable for a hobbyist to use sound.
Light (and so does laser) travels at 300,000km per second. Sound travels at 330m per second. So light travels at a speed 909,090.9090 times faster than sound.
It is much easier to measure a sound signal and gate it accurately with commonly used ICs.
Measuring in the range of 300m air density and relative humidity can almost be negligated.
Use ultrasound transmitters and receivers and build your timing and evalution circuit on that basis.
Measuring the distance between the earth and the sun it would make sense using light. If the sun decides to turn off its light it will be dark on earth eight minutes later.
Boncuk
Boncuk is offline
Old 19th October 2009, 09:20 PM   #6
Boncuk
Yea, but I still need to use laser ultra sound would have been to easy. Then i need to make it detect velocity.
axujiec is offline
Old 19th October 2009, 09:53 PM   #7
Default ... suggestion
Use two lasers in parallel ..... a fixed distance apart.
If the two lasers are both focused on the target, then the acute included angles between the lasers, along with the laser separation distance will provide sufficient information to compute the target distance .....
The construction problem is then reduced to how precisely you can measure the laser angles.
... This is know as the parallax method of determining distance.
user_88 is offline
Old 23rd October 2009, 09:59 AM   #8
This is very good and easy to make thanks. However I cant extend it to measure velocity in any way.
axujiec is offline
Old 23rd October 2009, 12:51 PM   #9
Hi all,
Thanks.
How are you reflecting the laser impulse. Will each distant object in question have a reflector of some sort?
Pay it forward.
Mikebits is offline
Old 23rd October 2009, 02:21 PM   #10
Yea it would have a mirror
axujiec is offline
circuit, timing
Timing Circuit ormo Electronic Projects Design/Ideas/Reviews 1 23rd November 2008 06:32 PM
Timing circuit with buzzer tomtailford Electronic Projects Design/Ideas/Reviews 16 30th April 2008 06:00 PM
Timing circuit. snug_gles Electronic Projects Design/Ideas/Reviews 6 1st April 2008 05:58 PM
Need Help with a Timing Circuit gb043 Electronic Projects Design/Ideas/Reviews 4 8th September 2004 04:32 AM
Timing Circuit?? CraigC Electronic Projects Design/Ideas/Reviews 4 7th November 2003 11:05 AM
