+ Reply to Thread
Results 1 to 10 of 10
Thread: Audio Impedence Matching Circuit
  1. #1
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    Question Audio Impedence Matching Circuit
    I have a PA amplifier. Its output power is 70W, 100V, 4-16Ohms.
    What I want is a small circuit to give inputs from the above amplifier (output) to another amplifier (input) rated 470mV/10Kohms specifications
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    Just a simple attenuator off the speaker output - often this is already included in the amplifier, and marked 'slave output'.
  3. #3
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    Hi Nigel I don't know what is an attenuator !
    The speaker is in very far.So I need to take the signal from the speaker to the input of the 2nd amplifier (470mV/10Kohms).
    What should I make?
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    An attenuator is a 'potential divider', one of the most basic of electronic 'circuits' do you know what that is?.
  5. #5
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    Ok thanks but PA speaker systems have another transformer inside the speaker.
    Do you telling to use a voltage divider input of the transformer (same amplifier output) or output of the transformer (final speaker lines).
  6. #6
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    Ok I checked the PA Speaker it has Rated Power = 10W/100V.
  7. #7
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    I just calculated divider resister values.Top resister should have 2.2Mohms & the bottom resistor must have 10K.
    Is my values ok?
  8. #8
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    Quote Originally Posted by Suraj143 View Post
    Is my values ok?
    Try it and see - however, you're better off tapping from the 4-16 ohm ouput, as the 100V transformer output 'may' be isolated - if not, then it's fine to use the 100V. I would suggest an initial 100/1 ratio if you're tapping off the 100V line, bringing it down to about 1V
  9. #9
    Suraj143 Newbie
    Join Date
    Jan 2007
    Location
    South Mald Isld
    Posts
    921
    Here is the circuit I'm going to build is it all right?
  10. #10
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    If you use very high value resistors like 2.2M feeding 10k then you will lose high audio frequencies and will not have enough output level.
    Use 22k ohms /0.5W feeding 470 ohms /0.25W ohms then turn down the volume control on the second amplifier to the volume you want.
+ Reply to Thread
  1. passive audio impedance matching
    By scrawny git in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th April 2009, 02:39 PM
  2. impedence
    By justlearning in forum General Electronics Chat
    Latest: 21st December 2006, 02:33 AM
  3. Impedence
    By beenuseren in forum General Electronics Chat
    Latest: 11th July 2006, 10:48 AM
  4. Impedence matching.
    By lord loh. in forum General Electronics Chat
    Latest: 6th June 2005, 10:46 AM
  5. Transformaer Impedence matching.
    Latest: 28th May 2005, 02:36 AM
Tags for this Thread
