Old 11th October 2009, 02:52 PM   #1
Default ring counter circuit
i have made a ring counter ot of 4013 ic .
i connected a manuall switch to clock circuit (S). because i want to manually control the ring. when s is pressed clk circuit generates a pulse which is input to 4013 . so L1 should be on and L2 off
at another press L1 off and L2 on.
for startig this circuit i connect Q1 to high and then disconnect it.
problem is that both L1 and L2 are on .
HELP
neptune is offline
Old 12th October 2009, 02:41 AM   #2
Not a very clear diagram. But here are some things I see wrong with it:
Q1~ and Q2~ should NOT be tied to Vss.
L1 and L2 (LEDs?) should have current limiting resistors. Try 1K.
Your clocking/Power switch circuit makes no sense. You need a steady 9V on Vdd. Then you also need to debounce the switch before feeding it into the clock input of the 4013.
kchriste is offline
Old 12th October 2009, 12:33 PM   #3
oh sorry there was a mistake !!!!
i connected vdd to manuall switch.
i should connect permanently to vdd.
i think q~ should be grounded.
so,for the rest of the part the logic of circuit is wright.
neptune is offline
Old 12th October 2009, 12:37 PM   #4
How many times must we tell you, you must not ground or connect directly to +Vsupply any of the 4013 OUTPUTS.
As I explained yesterday on the Chat line, your not circuit is not right...
ericgibbs is offline
Old 12th October 2009, 12:59 PM   #5
Hi neptune,
here is a sequence of screenshots using all four outputs of a 4013. There are always two outputs high and two are low.
Compare the pictures and select what you want. The input circuit is a debouncer circuit.
Boncuk
ring counter circuit-4013-1.gif   ring counter circuit-4013-2.gif   ring counter circuit-4013-3.gif   ring counter circuit-4013-4.gif
Boncuk is offline
Old 12th October 2009, 01:08 PM   #6
Hi Eric,
he can't read your post because of heavy smoke development from the circuit.
Hans
Boncuk is offline
Old 12th October 2009, 01:11 PM   #7
Originally Posted by Boncuk View Post
Hi Eric,
Hans
hi Hans,
I discussed this circuit with him yesterday, in detail, on the chat line.
'agu' has also told him the same thing on his other 4013 thread.
Old 12th October 2009, 01:27 PM   #8
ok, where then should i connect the unsed pins
neptune is offline
Old 12th October 2009, 01:28 PM   #9
You dont need to connect unused OUTPUT pins [/Q] to anything.
Old 12th October 2009, 01:30 PM   #10
Hi Eric,
Hans
ha ha very funny...
may be i am not smarter then u guys.
but atleast im trying.
neptune is offline
Old 12th October 2009, 01:30 PM   #11
good now thats a clear answer...
neptune is offline
Old 12th October 2009, 01:38 PM   #12
hi neptune,
My concern is that if you have been running the 4013 wired in that configuration, the 4013 may have died, so you may not get the operation you are expecting.
Old 13th October 2009, 02:11 PM   #13
no i dont connect anything , physically test the circuit, before knowing it.
also one thing "boncuk" circuit is not a ring counter.
he has connected q1 to clk2. but in circuit clk is common for alld f/f
neptune is offline
Old 13th October 2009, 02:14 PM   #14
Thats good.
Please post the LED sequence you want as the switch is pushed.?
Old 25th October 2009, 01:54 PM   #15
here is the schematic of circuit. using 40174 hex d f/f IC.
the switch connected is manual. manually press the switch and ring will run.
i connected d1 to logic high for starting this circuit.
problem is that all of the led's are on irrespective of where i conectd the d1 input.
neptune is offline
circuit, counter, ring
telephone ring delay circuit bond000 Electronic Projects Design/Ideas/Reviews 3 10th May 2009 09:42 AM
Counter circuit pas_cktmaker Electronic Projects Design/Ideas/Reviews 5 3rd October 2007 04:10 PM
Phone ring detector circuit dirtyb15 General Electronics Chat 1 12th July 2005 01:46 PM
Twisted Ring Counter 111 Electronic Projects Design/Ideas/Reviews 1 6th July 2005 10:36 PM
counter circuit, HELP!!! sion Electronic Projects Design/Ideas/Reviews 1 23rd March 2004 06:56 PM
