| | #16 |
| By looking at how the LEDs are connected, or by looking at the schematic of the circuit (it doesn't have a schematic?).
| | #17 |
I would think that looking at which side the flat on the LEDs are connected to should hopefully tell weather the PIC outputs are going low or high??
| | #18 |
| The flat sides connect together. The round side of each LED connects to an individual resistor, then the resistor goes to the IC.
| | #19 | |
Then you are lucky that the micro-controller can also turn on an input of an ULN2803 IC or turn on an NPN transistor.
| | #20 |
parallel LEDs unless they are all the same voltage drop etc. we is talking 250 LEDs here. the 2803 is perfect choice but then what? a kizillion resistors and ??? I would still opt for using the ULN2803 driving several SSR's I think the photo showed 10 LEDs? so 10 SSR's then xmas light strings. EASY way out | |
| chaser, led, mod |
| LED turn signal chaser mod/question | Sockles | Electronic Projects Design/Ideas/Reviews | 7 | 26th September 2009 08:04 PM |
| LED Chaser | ormo | Electronic Projects Design/Ideas/Reviews | 2 | 3rd November 2008 03:21 AM |
| need help with LED CHaser | impulseballer | Electronic Projects Design/Ideas/Reviews | 10 | 16th May 2008 04:23 AM |
| Scavenging 4017s for LED chaser | Bynari | General Electronics Chat | 10 | 16th January 2008 05:14 AM |
| Chaser LED IC Help | fiveten | Electronic Projects Design/Ideas/Reviews | 1 | 22nd February 2005 02:17 AM |
