Originally Posted by
Andrew Leigh
Hi Eric,
Will this be significantly more design work for you? If the design is not finalised before you leave for S.A. I am unable to carry on. The idea sounds great as the accuracy will improve.
I will not have time to complete before I travel, I would be happy to restart in the New Year on Ver2 with proportional heating control.
You have plenty to do so really I am in your hands as I don't have the skill. If you are OK with it i'm in.
Am I correct in stating that the circuit as it currently set works by pulsing the heater in very short bursts of about 100ms on and 60ms off.
No, its either On or Off depending whether the tempr of the fridge is cold or warm, as it was in the original design
This is because we have set the time between any voltage change at the thermistor at intervals of 0.1 sec. In reality this time frame is probably too short for any response from the thermistor so the pulses would be a little less frequent?
Not applicable without proportional Triac control on this version.
Cheers
Andrew
