Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
Hi Eric
Downloaded Winzip 14.0, the latest version, the same result. What program did you use?
Cheers
Andrew
Hi Eric,
thanks.
Have logged onto the yahoo group. Have found the LM393 and the MOC308x series but can't get the .sub files. Can these be created from the .txt files?
In the meantime using the LM339 as it has a .sub file but I am being stopped at the opto.
Cheers
Andrew
All the files you need are here, get them all
http://tech.groups.yahoo.com/group/L...TO%20TRIAC%20/
Hi Eric,
progress but can only get one cycle of current to the heater then it switches off?
Hey, this could be a bunch of fun and a great learning tool.
Cheers
will do.
In the files I could only find the LM339.asy file , got it "working" and in my excitement forgot to go back and track down LM393A. Will go and find it, correct the background and post.
Cheers
Hi
Yeah but unlike me you actually know what you are doing
You have not seen me give up yet.
Cheers
I have searched for a the right 393 but have got nowhere??? I can't seem to find the LM393A symbol file?
Cheers
Andrew
Attached is the .asc
OK,
I got it, don't know how but I think it has something to do with when or how I refresh the model. Will carry on playing for a while and substituting differing R9 values.
Andrew
Hi Eric,
this puppy is frying my brain. I have;
- Altered the resistances at the pots and brought them to the levels for -8°C (the evaporator temp where the thermistor is located. I increased the two 5V setting in the Thermistor model to 6.5V the OFF temp for 0°C. Is this correct?
- Inserted the Triac as per the MOC data sheet but could not find the identical one. Note how current continues to flow in the OFF period? When increasing the value of R15 from the data sheets 39R to 100k I can get the current to stop flowing on the OFF period, is this right?
- Have altered the heater resistance to 275R (the heater is 175W). The heater should draw 0.8A, the circuit is drawing about 1.15A, is the resy going into the circuitry?
I hope I am getting somewhere, I need some help please!
Cheers
Andrew
from spice. Just over half the way down this page. TECCOR SCR's and Triacs
http://tech.groups.yahoo.com/group/L.../files/%20Lib/
Cheers
Andrew
