+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 33
Thread: 13.5 volts into a 555 timer ?
  1. #1
    fatfenders Newbie
    Join Date
    Sep 2008
    Posts
    19
    Default 13.5 volts into a 555 timer ?
    I recently purchased a "Canakit" Mini Electronic Timer I want to install on my motorcycle. Instructions indicate I can use 9 or 12 volt input. I would like to just use the MC 12v system but, of course, the voltage can go up to around 13.5
    There are few components on the board and I guess the one I would have to worry about is the 555 timer. When they say "12 volts" do the really mean it or could I just go ahead and hook it up to my MC electrical system?
  2. #2
    Robert_G Newbie
    Join Date
    Sep 2009
    Posts
    11
    Can you see the actual chip number on the 555 timer? There are different ones, but I believe most can go up to 18V MAX (don't want to run it there all the time). But if this is a device designed for automotive "harshness", you should be fine.
    Although not sure I'd hook a 555 timer directly to an auto application without some kind of regulation or filtering at a minimum.
  3. #3
    Robert_G Newbie
    Join Date
    Sep 2009
    Posts
    11
    I just looked up that device you have. What is the full chip text and what voltage are the capacitors rated at?
  4. #4
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    If 2 extra volts causes a failure in the discrete components on the circuit board the engineer that designed it should be dragged out and shot.
    straight answer, har har."
  5. #5
    jimlovell777 Newbie
    Join Date
    Mar 2009
    Posts
    133
    If you're concerned and your circuit won't be drawing much current a crude solution would be to add two diodes in series with the power connection.
  6. #6
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    2,174
    You can also drop the voltage with a 12V zener, a resistor and a transistor. Connect the resistor and zener to the transistor base, resistor to the B+ and zener to ground, the junction of these two components to the transistor base. Transistor collector to B+ and take the voltage for your project from the transistor's emitter. You'll get about 11.3V from this arrangement.
    Lions and tigers and bears, OH MY!
  7. #7
    bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent
    Join Date
    Jul 2009
    Posts
    726
    Quote Originally Posted by Robert_G View Post
    True, and the IC will eventually die on a motorcycle unless some kind of series R and Zener protection is provided. I found that out the hard way, motorcycle electrics have a lot of transisents on the line. It killed my 555 flasher unit.
  8. #8
    Join Date
    Jul 2009
    Posts
    726
    Quote Originally Posted by Sceadwian View Post
    Transients on auto/MC electrics can easily hit 50+ volts for brief periods but long enough to do damage.
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    2,174
    Quote Originally Posted by bountyhunter View Post
    Man, that's good advice. I haven't tried to connect anything to my MC yet, but I'll keep that in mind when the time comes.
  10. #10
    MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent
    Join Date
    Apr 2007
    Posts
    2,135
    Default thats why the make LDO regulators
    for automotive applications.
    here is an adjustable one for 3 - 20 v
    they do have non adjustable ones as well
    National Semiconductor - LM2941S/NOPB - Allied Electronics
  11. #11
    Join Date
    Jul 2009
    Posts
    726
    Quote Originally Posted by MrDEB View Post
    The lm2940/1 do have built in surge protection up to 60V specifically for automotive applications. They are generally junky parts, but they will survive in auto electrics better than most ICs because of that.
  12. #12
    fatfenders Newbie
    Join Date
    Sep 2008
    Posts
    19
    Thanks much for all the responses...
    As you can tell by my question I am just a hack at this stuff but, armed with the information you have provided, I have an idea on how to proceed. Today I drew up a circuit and will try and build it. When I (1) am successful or (2) have to admit to utter defeat I will post results.
  13. #13
    Join Date
    Jul 2009
    Posts
    726
    Quote Originally Posted by fatfenders View Post
    If you can define the exact function you need the timer to do, there are probably lots of circuits out there already canned up. I use 555's for the turn signal flasher on my bike right now.
  14. #14
    electronspeed Newbie
    Join Date
    Aug 2009
    Posts
    63
    If voltage goes beyond prescribed level then a number of components are available.One can go for zener(Vz=12v) or you may go for 7812(voltage regulator.)
  15. #15
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,458
    I strongly recommend to use a transil diode to eliminate spikes.
    Spikes also kill CMOS-devices before they even start working.
    Attached is a datasheet of such a device.
    A low drop out voltage regulator would also reduce spikes and ripple.
    Use both, the diode and the regulator for safe operation.
    Boncuk
+ Reply to Thread
Page 1 of 3
1 2 3 Last
  1. 555 timer
    By johnny in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th February 2009, 03:06 AM
  2. Multi-Mode Universal Timer ( 12 Volts )
    By petelai in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th July 2008, 08:00 AM
  3. How can I get 3 volts to trigger a short circuit??(skateboard timer)
    By scuppers in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd March 2008, 11:46 AM
  4. 555 timer
    By femodee in forum Datasheet/Parts Requests
    Latest: 14th June 2005, 07:39 PM
  5. 555 timer, thanks.
    Latest: 10th April 2003, 02:32 AM
Tags for this Thread
