| | #16 | ||
![]() Do the maths, and work out the speed and precision you need. | |||
| | #17 |
hey there everyone, I've been trying with my project lately and I came up with these results: 1- My first approach was to use Signal power as a parameter to be utilized to determine distance.This did not go well since I'm using a ready made RF transmitter with a range of 3000 Km!! so obviously no change in power would be detected. 2- Second, I tried the phase detector consisting of an XOR + RC(low-pass filter) but I got a constant reading so I need someone to tell me how to choose the values of R and C (probably I chose wrong values ).3-Now I'm planning on calculating the round trip time to figure out distance as follows: TX1 ----> RX2 RX1 <---- TX2 where I will use a Microcontroller to start a timer as soon as TX1 sends the data and the timer will stop as soon as RX1 receives a confirmation signal. but I need some advice to pull this off so it would be greatly appreciated, and I know that all of U guys are professionals, so any advice would really help. thx in advance. | |
| | #18 |
Your data is 2.4kHz, and you're running the sent and received signals through a phase detector. The propagation (wavelength if you will) is about 12 km. One eighth of that (round trip, 90 degrees) is 40km. So your phase detector gives you 0-Vcc from a measured distance of 0-12km. 2) Using 5V as Vcc, and assuming your timing on the phase detector is set to maximize the slope, your phase detector should give you a voltage delta of (5V/12km) or about 400 microvolts for a one meter distance change. Can you consistently measure 400 microvolt changes? It would require a 4-1/2 digit multimeter, for example, to measure to the nearest meter. Your phase detector power supply should be stable to 100 parts per million to avoid introducing spurious results. 3) Using a timer, assuming a 10MHz clock rate, each tick of the timer equals a round trip distance of 30 meters (round trip 15 meters). That's your basic resolution, assuming a perfect transmitter/receiver..
__________________ de KI6RWX Last edited by mneary; 5th November 2009 at 12:02 PM. | |
| comparator or detector, lm565, phase |
| Phase Detector | Krenzo | General Electronics Chat | 5 | 11th November 2008 12:23 AM |
| Phase sequence detector Problem | neelam29 | General Electronics Chat | 5 | 26th June 2007 07:12 PM |
| 3 phase sequence detector | andrew2022 | Electronic Projects Design/Ideas/Reviews | 1 | 24th April 2005 05:46 PM |
| JK phase detector | jovabiot | Electronic Projects Design/Ideas/Reviews | 3 | 24th March 2004 01:27 PM |
| PLL(phase detector) | Oluvision | Electronic Projects Design/Ideas/Reviews | 2 | 31st January 2004 07:16 AM |
