| I'm Currently doin a project using voice recognition to unlock a door. Im planing to use the PIC16F877 microcontroller.Is it possible?? Im havin difficulty to start on the microphone circuit, the filter circuit which allow the range of 300-3400hz to pass through. Which kind of filter should i use. Im also havin dificulty on the Aanalogue to Digital conversion of voice to allow the microcontroller to recognize the input. How should i build it?? Finally im using mplab to program the microcontroller for it to recognize the input voice of 80% accuracy to unlock the door? Do u hav any idea how should i wrote it?? | |
Certainly if you are struggling with simple filtering, the project sounds rather complicted for you - all you need is a bandpass filter, or a lowpass and a high pass - there are certainly plenty of circuits out there for voice bandwidth filters, try amateur radio sites. | ||
| thats a big job for a PIC. voice recognition needs complex algorithms. a DSP or an FPGA might be able to do this job. | |
| Yikes... if it were me, I'm not so sure I'd want to use voice recognition. There could be too many flaws in it. If you're looking for a keyless/codeless solution, maybe you should go for fingerprint reading. But, that's me. 8)
__________________ When life gives you lemons... make a battery. | |
| As Nigel pointed out ther are commercial voice recogintion modules at remarkable low prices to be found. Not that $50 american is cheap, but considering the small miracle it has to perform it is not that bad It may be to much for a pic on its own, however many years ago I do recall seeing the hex code for speech recognition using the humble ZX81, surprisingly this humble machine still has a few devoted owners on the web. They might just might have an idea or two how it could be done with a microcontroller or try bouncing the idea off one of the PIC forums that abound on the web. | |
| there's a company called sensory that makes a drop in voice recognition chip. Writing your own voice recognition code is really not an option - the required level of knowledge on human speach is really high. Brent | |
