Old 19th September 2009, 07:30 AM   #1
Default Swapping out a MOSFET for as IGBT?
Hi, I was told that I could build this circuit http://uzzors2k.googlepages.com/ET_F...basic-full.jpg
and swap out the MOSFET for a big IGBT I have (FGA15N120ANTD).
However, I was told I would need to use some kind of transistor to switch the gate, and they also said to use 50% duty cycle.
Any help with these 2 things would be appreciated
Dan
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 21st September 2009, 05:02 PM   #2
You will need some sort of gate driver for that IGBT. It is HUGE. You can either build your own gate driver circuit (not recommended) or buy one of the many available ICs for it.
Not sure what the 50% duty cycle thing is about.
smanches is offline
Old 21st September 2009, 05:47 PM   #3
OY! you need a snubber on that... and why on earth to people insist on using 555s for things these days?
you would be better off getting a real regulator chip meant for the job than hacking some crappy 555 ckt to a fet driver.
Ubergeek63 is offline
igbt, mosfet, swapping
igbt vs. mosfet. why choose? JohnWondersWhy General Electronics Chat 16 25th October 2009 08:47 PM
IGBT and MOSFET in parallel khalid4145 General Electronics Chat 0 20th November 2008 12:19 PM
Hot Swapping Protection IC DigiTan Datasheet/Parts Requests 0 11th June 2008 12:32 AM
swapping polarity electronically atf1084 Electronic Projects Design/Ideas/Reviews 10 6th January 2008 12:18 PM
IGBT and MOSFET help dstich General Electronics Chat 5 14th January 2004 07:29 PM
