+ Reply to Thread
Results 1 to 9 of 9
Thread: Looking for a solution
  1. #1
    wingnut517 Newbie
    Join Date
    Sep 2009
    Posts
    4
    Default Looking for a solution
    OK - Not gonna beat around the bush - I am a complete novice!! (but not ID 10 T error either)
    What I am trying to do (and I must add for as little money as possible) is simply put either a delay in a button push. Let me explain a little better
    I have a momentary button wired to light A and from light A it is wired to light B.
    When I push the button, light A and B illuminate at the same time. What I need it to do (the simplest way possible) is to hit light A, then hit light B - this could be a 1/4 second delay - I don't care, I just need them to illuminate in order rather than simultaneously.
    I am not really using lights in this scenario, just felt it was the easiest way to explain what I am trying to accomplish. I basically want to be able to push a button and have action A happen, then a split second later have action B happen.
    Any help or guidance would be appreciated!!
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,003
    Well, the best way to do that somewhat depends upon what you are powering (if not lights).
    How much power and voltage?
    Is it AC or DC?
    Can you use a relay, or do you want it to be solid-state?
    Carl
    Curmudgeon Elektroniker
  3. #3
    wingnut517 Newbie
    Join Date
    Sep 2009
    Posts
    4
    It is a video game controller - It uses 2 AA batteries but I have a current modification on it that I have added a wall wart as well. so I can use either AC or DC.
    I honestly do not know a relay from a resistor from a capacitor but I am not afraid to dig in and learn what I need to learn to get this done. I'm a 40 year old man with a soldering gun trying to make his daughter happy. I am simply unsure what to look for at this point.
    If someone replied " Yeah if you rub your tummy real hard while standing on one foot while you push the button it will work" I would try it.
    Is what I need to research a relay??
    Would it be easier if I took pics and explained what I am doing a little better??
  4. #4
    EN0
    EN0 is offline
    EN0 Newbie
    Join Date
    Jul 2009
    Location
    Outer Space
    Posts
    223
    You could try a parallel RC circuit delay. According to the equation: T=RC where T represents time, R represents resistor, and C represents capacitor. Make sure you complete all the values, so if I have a 10k resistor make sure you have 10,000 in the equation.
  5. #5
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,701
    Blog Entries
    5
    Are there no mods available for your controller you can buy?
    Bill
    Smart Kits build Smart People
  6. #6
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    You will need a transistor, an electrolytic, a few resistors, a relay and 2 diodes. Are you able to get these types of components?
  7. #7
    wingnut517 Newbie
    Join Date
    Sep 2009
    Posts
    4
    blueroom - I wish I could simply buy it, and yes I have a shop right around the corner from me - I actually might just take it there and see what they say - might be easier
    I guess the problem with me stating I would do anything and that I knew nothing, is I will not be able to recognize a good solution so if you agree with someone else here, please say so!!
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,701
    Blog Entries
    5
    Usually it's a small 8 pin PIC microcontroller.
    Bill
  9. #9
    wingnut517 Newbie
    Join Date
    Sep 2009
    Posts
    4
    1 shameless bump
+ Reply to Thread
  1. is my solution ok?
    By transgalactic in forum Math and Physics
    Latest: 27th January 2010, 08:22 AM
  2. is my solution correct ..
    Latest: 22nd August 2009, 11:49 AM
  3. Can you suggest a solution?
    By RobertRoss in forum Micro Controllers
    Latest: 22nd April 2009, 05:44 PM
  4. A possible solution [Re: Walters]
    By mstechca in forum Chit-Chat
    Latest: 21st February 2006, 07:01 PM
  5. Help me find a solution
    By Leolight in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th December 2004, 10:08 AM
Tags for this Thread
