Old 24th June 2004, 11:33 AM   (permalink)
Default Increase the range of RF transmitter/receiver
Hi All,
I've recently (4:30am this morning :cry put in a car alarm.
Now I'm not too sure if it's just the batteries or not, but it seems to have a fairly short range. Now it's not too bad when you want to unlock or lock the car, but for the remote boot release the signal has to stay working for 3.5 seconds, which means if the signal is broken I have to start the process again.
What I really need to do is to increase the range. Preferable around 50m, but if possible 200 metres+ would be great. If anyone knows how to get it up to 1km.. I would very much like to know about it 8) 8)
I'm still unsure how I would go about it, whether I increase the range of the receiver or of the transmitter. My one problem is that its not one of the higher quality rolling code alarms, so if the transmitter receives the same frequency as someone elses remote puts out I'd be in trouble.
Thanks to all who at least read this, and I hope there are some ideas as to how I can increase the range.
Thanks in advance,
Tim.
letsrelaythat is offline
Old 24th June 2004, 11:52 AM   (permalink)
These transmitters are 'licence free', which means there are strict restrictions on the power you can use - it will probably already be as high as it can be.
Your biggest improvement would probably come from the receiver aerial, if it's under the bonnet it will be screened and perform really badly. Moving the aerial outside the car will increase range considerably.
Old 24th June 2004, 12:01 PM   (permalink)
Is there any way I can extend the aerial from the main unit, I just had a thought about using the car aerial.
I was thinking of putting a relay in line, so that when the car is on ACC, the relay clicks over and gives the signal from the aerial to the radio, otherwise, the aerial picks up the RF transmissions and works a whole lot better..
Would this work or should I just get a new aerial.
Thanks in advance,
Tim.
Old 24th June 2004, 12:13 PM   (permalink)
its not much aof a long term solution, but I know for a fact that if you put the remote against your head, you body acts as an aerial, and extends the range...
Tim
grrr_arrghh is offline
Old 24th June 2004, 12:28 PM   (permalink)
Lol I went outside and tried it, I hope it wasn't a joke cause I would have looked so stupid ops:
My mate said that becuase the receiver is inside the car, that severly decreases range. Do the receiver units have like a one wire antenna? Could I use the car antenna like I hope??
Thanks in advance,
Tim.
Old 25th June 2004, 02:06 AM   (permalink)
These things have precisely tuned antenna's, usually etched on a PCB.
Connecting external random wires would, IMO, not make much difference.
The remote is designed to work for a certain distance, why is it so hard to walk close enough for it to work :wink: , after all you are getting to YOUR car, are you not? :twisted:
Just push the button when you are standing next to the car.
Klaus
Klaus is offline
Old 25th June 2004, 02:13 AM   (permalink)
Exactly. its not restricted until you get caught. and what cop is gonna check the power going in to your car alarm receiver.
dustinpruente is offline
Old 25th June 2004, 02:17 AM   (permalink)
if the antenna is just a wire, then run it and solder it to the body or chassis of your ride, man then the whole frickin thing works like a gigantic antenna. Problem solved.[/i]
Old 25th June 2004, 04:58 AM   (permalink)
If you do that you'll ground the signal and you'll get nothing, and possibly smoke your reciever
gerty
gerty is offline
Old 25th June 2004, 05:06 AM   (permalink)
Dustin,
Your idea will work only if you disconnect the receiver's ground from the car's chassis and connect it (and new power for it) to earth. Ohterwise, you are only shorting the antenna to signal ground.
audioguru is offline
Old 25th June 2004, 08:41 AM   (permalink)
hai guys,
I don't know if this is a good idea :lol: can we add an antena to the transmitter.
tq
rookie is offline
Old 25th June 2004, 09:08 AM   (permalink)
Again, that breaks the licence free conditions, and would be illegal - in response to previous comments about that, I know that the chances of being caught are slim - but it's still illegal, and it would be negligent not to make people aware of it!. If you want to then ignore it, fair enough
The main problems with any changes to the transmitter are it's small size, any changes (including a larger aerial) are going to make it considerably larger.
I also don't quite see the reasoning behind wanting range from 50m to 1km - you may as well leave the doors unlocked and hang a 'please steal me' sign on the windscreen :lol:
Old 25th June 2004, 12:32 PM   (permalink)
Just to touch on the comments about ignoring the regulations - there are agencies that "listen" across the bands however it would be safe to conclude that there aren't enough enforcement personnel to go after small stuff. The risk you take is in interfering with something or someone else then they take steps to track you down.
An example - I am an amateur radio operator so I do what I do with RF for fun and to learn. I talk with others in my community many of whom are skilled technical folks who make their living in communications and broadcast work. I'll often hear from them about an "offending" signal and their efforts at tracking it down. The offense (or offence) isn't in the fact that regulations are ignored, it's that it's getting in the way of their operations that make them money. They may have paid a lot of money to use a frequency. Now and then an offending signal will appear on the amateur bands and we'll collectively work on it until it's gone. More often than not the source is found and usually the approach is to point out the interference problem - that works most of the time. When it doesn't we enlist the aid of the FCC or other agencies. Most of the time the offending signals result from commercial transmitters or equipment but now and then it's deliberate and unauthorized transmission.
I'd agree that the momentary push of a button isn't likely to get a lot of attention unless that momentary push was near the same location where it bothered something - and someone makes the connection to your activities.
stevez
stevez is offline
Old 26th June 2004, 12:40 PM   (permalink)
well seeing that the chances of being caught with an illegal RF device is pretty slim, there were reasons why it was illegal. Ambulance services also use radio communications, so if they fail because RF interference is being made an illegal device, somebody could die or something. It might even be you one day...
Then again 3.5 secs interference...pfft... just boost the supply voltage to the transmitter. This is the easiest way i know to increase range.
Off topic: England VS Australia -go the wallabies!!
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
Old 26th June 2004, 05:20 PM   (permalink)
ive never tried my second idea, as i have put a new signal-sensitivity controller in mine and broken the "License Free" law completely, i get about a half mile range, and i changed the frequency crystals to a freq used only by the secret service when the prez is in town.
