+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 20 of 20
Thread: First, tiny project
  1. #16
    MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent MrDEB Excellent
    Join Date
    Apr 2007
    Posts
    2,135
    Default you don't need the tip 120
    I copied n pasted from a larger schematic.
    I thought I took that out??
    for one LED all you ned is a 2n2222
    sorry for the booboo
    you still need to add a resistor to led depending on voltage.
    see audiogurus post
  2. #17
    Join Date
    Apr 2007
    Posts
    2,135
    Default look at my LT spice post
    reconfiguring so LED turns on slower
  3. #18
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by smudgepost View Post
    I am basically going off your schematic MrDeb.
    Don't make MrDEB's defective circuit:
    The timing resistors are backwards so it will ramp on the LED fairly slowly then will try to switch off for such a small amount of time that the LED will appear to be on continuously.
    But since there is no current-limiting the LED will burn out.
  4. #19
    smudgepost Newbie
    Join Date
    Sep 2009
    Posts
    9
    This thread has grown and I'm really pleased. I want to try building them all! I am stuck on time for version 1.0 of this so will likely stick with 555 but if the newer 7555 idea works better then I might just use that. The keypad interface is very interesting and will read more tomorrow. I will likely run with the double 555 circuit initially and use a 2n2222 as suggested mainly as these are the parts I've got. If you could help me understand what I need to do to fix it before I burn it that would be great.
    As a recap, I'm limited on space so opted to use button batteries so could probably squeeze upto 6V inside. That' my only bottle neck in the planning. I also bought a 5mm and 3m super bright white LED for the flash and am plan to use a piezo for the sound. Oh and yes I would prefer a steady blink to a bold on/off flash.. if possible.
    I know some traditional people are against always reverting to a microcontroller, but it would be perfect for this situation.
    - you can get your timing perfect for the on/off ratio.
    - it can perform you fade in fade out function with a pwm
    - some run off 3v
    - 8 pin SMD chips are tiny
    - they can sink/source up to 25mA which is enough to drive an led.
    - minimal parts required, led, microntroller, 1 or 2 caps,battery, and a switch for function select.
    Of course the downsides are you need the programming knowledge and hardware
    Hardware - easy, know-how - not so easy..
  5. #20
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Button batteries have such a low capacity that the LED will turn on for only a few times. You must blink an LED fairly dimmly and for very short durations for some button cells to last for a few hours.
    Button batteries power items with an LCD display that does not produce light so its current is very low.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Looking for TINY Rx/Tx modules
    By strokedmaro in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th July 2008, 12:09 PM
  2. Really tiny computers
    By Marks256 in forum General Electronics Chat
    Latest: 5th March 2007, 08:40 PM
  3. Best tiny on/off switch
    By Oznog in forum General Electronics Chat
    Latest: 2nd September 2004, 06:14 AM
  4. tiny IC
    By computer in forum General Electronics Chat
    Latest: 6th April 2004, 06:30 PM
  5. tiny transmitter
    By KarrottoP in forum General Electronics Chat
    Latest: 8th October 2003, 10:42 AM
Tags for this Thread
