Old 16th September 2009, 03:44 AM   #1
Smile CRT Oscilloscope - controlling deflector coil with MOSFET
Hi.
I'm trying to control an old CRT using a microcontroller, and I need to drive the deflector coils with reasonably large voltages.
I've got a few questions I'd really appreciate some help with:
- To deflect the beam both ways, I need to be able to apply a positive and negative voltages to the coil. Simplest way, I figure, is to bias one side at a mid voltage, and swing the other beween 0 and the maximum. Does this sound reasonable?
- I'm not sure how to switch the larger voltage using the microprocessor's 5v output. I could use PWM to control a mosfet in saturation, or get an analogue voltage via a resistor ladder, to operate it in linear mode. How would I go about doing either of these, and as I understand I need Vgs to be greater than Vds in either case?
- The coil has a resistance of something like 60ohms. How should I isolate it from the power supply, so as to prevent it effectively shorting the supply when connected by the mosfet?
Any help would be greatly appreciated!
sleeper1987 is offline
Old 16th September 2009, 04:25 AM   #2
How about an H-Bridge?
Deflection amplifiers are usually a voltage-controlled current source.
Mike ML.
MikeMl is offline
Old 16th September 2009, 06:05 AM   #3
I would use an audio power amplifier chip. Just make sure it's stable into an inductive load.
de KI6RWX
mneary is offline
Old 16th September 2009, 01:47 PM   #4
Thanks for the replies!
As for the audio power amp: How can I tell if it's capable of handling inductive loads? Would any amp designed to drive speakers directly be ok for that?
Unfortunately, I'm restricted to buying from here, so there's little choice:
Power Amps : Maplin Electronics
Do any of those seem suitable?
Thanks again.
Old 16th September 2009, 03:55 PM   #5
Typically the vertical coils require little current and are slow to respond. They are built to run at 60hz. The horizontal coils take much more current and run faster. TV=15khz. VGA=32khz. The coils deflect the beam with current so the amplifier must have current feedback.
Is the CRT from a TV or monitor?
ronsimpson is offline
Old 17th September 2009, 02:06 PM   #6
Interesting! In that case, I'll probably rotate the coils so that the horizontal one is slower. The CRT's from a TV.
coil, controlling, crt, deflector, mosfet, oscilloscope
Oscilloscope CRT model replacement aledaniel General Electronics Chat 0 12th February 2009 02:00 AM
Gould DSO-400 Digital Storage Oscilloscope CRT rmn_tech Datasheet/Parts Requests 7 17th December 2007 11:09 AM
CRT Oscilloscope Aily Sajjad Electronic Projects Design/Ideas/Reviews 7 12th November 2006 05:13 AM
Controlling P-Channel MOSFET with MCU LiquidKernel General Electronics Chat 13 31st October 2004 01:22 AM
Advise needed for buying a oscilloscope CRT Learner General Electronics Chat 12 30th September 2004 05:16 PM
