+ Reply to Thread
Results 1 to 7 of 7
Thread: MCP2140A: IrDA communication with PC
  1. #1
    BuffaloEngineer Okay
    Join Date
    Jan 2009
    Location
    Buffalo, NY USA
    Posts
    86
    Default MCP2140A: IrDA communication with PC
    I'm having some major trouble with my IR connection with the computer. I got the MCP2140A because it was supposed to take care of the IR stack protocol needed to communicate with the PC, but I'm having trouble getting the computer to recognize it (it usually recognizes it for a second, the doesn't see it anymore despite the fact that it keeps sending IR pulses).
    I copied most of my schematic from a demo board of theirs, but still nothing. I don't think the MCU is even needed for the computer to recognize the chip. Just hoping someone out there can see what I'm doing wrong!
    (The 6 pin connector is for the MCU programming header)
  2. #2
    DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent
    Join Date
    Aug 2003
    Location
    Toronto, Canada
    Posts
    1,308
    I don't understand. How are you connecting this to your PC?
    Your schematic has a connection between the chip and a PIC. I don't see any connections to anything else.
    EDIT: Are you trying to connect this to the computer over that serial connection? Are you using a level converter for RS232?
    Mark Higgins
  3. #3
    Join Date
    Jan 2009
    Location
    Buffalo, NY USA
    Posts
    86
    I'm trying to connect to the computer through the IR port on the computer - mine has an IR window in the side of the computer. I've connected to it using a demo board, but not with my own setup.
  4. #4
    Join Date
    Aug 2003
    Location
    Toronto, Canada
    Posts
    1,308
    Reading up on it, it's confusing me more than anything. I've implemented IrDA, but only between uC's, so technically not real IrDA, since I don't need to conform to anything but the PHY layer.
    It looks like it's supposed to implement irCOMM itself, but I'm not certain. Have you tried looking at the sample frimware from their demonstration boards, like the logger and temp sensor?
    Mark Higgins
  5. #5
    Join Date
    Jan 2009
    Location
    Buffalo, NY USA
    Posts
    86
    I have the temperature sensor demo board, which works like a charm. I've used it to send and receive info through hyperterminal (after installing a virtual com port). There's no demo board with the MCP2140A, the temp sensor board uses the older version of the chip, the MCP2140, which is similar.
  6. #6
    Rabbitsfot Newbie
    Join Date
    Sep 2009
    Posts
    1
    Default Check the PHACT pin...
    Check the state of the PHACT pin. It will tell you if the chip's state machine is in the discovery state or not. Check that you have a pull up on that pin since its OC.
    Check the DSR pin which will tell you if you are getting a link from the chip.
    Confirm that the DTR and RTS pins are low.
    In, general read the manual and ask yourself if each pin of the part is in the state it should be according to how the part operates as described by its data sheet.
  7. #7
    Join Date
    Jan 2009
    Location
    Buffalo, NY USA
    Posts
    86
    Quote Originally Posted by Rabbitsfot View Post
    Thanks - have you used this chip before? I keep the DTR at GND, but I've been trying the RTS both ways because I wasn't sure whether to keep it high or low, so I'll keep it low.
+ Reply to Thread
  1. bluetooth and IrDA
    By nilesh.7650 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd May 2007, 03:45 AM
  2. irda
    By rakhiwilliams in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th April 2007, 01:49 PM
  3. Help with IRDA wow
    By stanza in forum Datasheet/Parts Requests
    Latest: 12th December 2006, 08:19 AM
  4. IRDA project
    By adrian120 in forum General Electronics Chat
    Latest: 5th September 2004, 05:57 PM
  5. IRDA project
    By adrian120 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th September 2004, 05:44 PM
Tags for this Thread
