Hello.
1st time posting on these forums. I did electronics at a-level, but haven't done anything for a good 10 years so most of the stuff i learnt, i've completely forgotten.
I need to supply split rail power of +/- 15v. The power requirements aren't that great. I'm only powering a quad op amp and 24 led's
I currently have a bench psu capable of producing 30v dc, but it won't work as a dual output supply, even though i was assured it would!
I have read about virtual grounds which i could use to produce a split rail supply.
If a virtual ground is not suitable, then could someone point me in the right direction for building one using a transformer and some sort of rectification for both positive and negative supplies. I guess i'd use the centre tap as the ground.
Cheers
Martin
