I am working on a product that has wires (+/-ve) connected from a contact pad on the surface of the product. The contact is for charging battery. The wire is about 5cm long and connects to the PCB. When contact discharged on the contact pad, there is significant radiation from the wire that causes disturbance in other products in the vicinity (withing 2-5cm away).
I am trying to contain and dissipate the radiation caused by the ESD discharge. Any ideas how this can be done?
If I use shielded wires, where would the shield be connected to since these products are small and do not have chassis ground. It has system ground plane on the PCB. I could add a copper tape on the case to use as chassis ground. Any thoughts here would be helpful.
Thank you
Binu
