Hi I am building a portable GPS app. My power source will be 3 AA 1.2V rechargeable batteries that give 3.6V but, some of my parts require 3.3V +- 5%. My app will consume at the most 900mA. I have checked out several DC-DC step-down IC's but the most of them need more than 4V input to give out 3.3V and the current my solution demands. Do anyone know of a solution for my problem? Could a zener diode (3.3V) and some capacitors be a good solution? | |
You could just use a diode with a lower voltage drop across it. Although most low voltage logic systems are still not that fussy about how accurately the voltage is maintained. Being only .3 volt over the rated limit shouldn't cause any problems. Its still under the 10% over range limit thats common in most electronics devices. My Computers system monitor doesn't register a over voltage alarm point until 3.9 volts on the 3.3 volt DC buss.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
You could use a low dropout (LDO) linear regulator such as the LT1963A Linear Technology - LT1963A - 1.5A, Low Noise, Fast Transient Response LDO Regulators.
__________________ Carl Curmudgeon Elektroniker | |
Ok. Thank you for your replays! I will check out the regulator from Linear and also how sensitive my components are to 3.6V. But aren't the regulator better suited to supply more/"cleaner" current than no regulator? | |
| dcdc, power, supply |
| conversion of pc supply to high power rating supply | kamran sadiq | Electronic Projects Design/Ideas/Reviews | 3 | 17th July 2009 08:25 AM |
| ATX power supply -> lab bench power supply | Cobalt60 | Electronic Projects Design/Ideas/Reviews | 29 | 6th March 2009 09:09 AM |
| PC Supply -> Variable Power Supply + Function Generator | transistance | Electronic Projects Design/Ideas/Reviews | 1 | 2nd March 2009 02:16 PM |
| Linear Power Supply vs Switching Power Supply | 2Electrified | General Electronics Chat | 9 | 3rd October 2008 07:13 PM |
| Power Supply Experts!! Need help with KEPCO Labs Power Supply | headbuttking2 | General Electronics Chat | 1 | 24th October 2006 02:05 AM |
