Old 31st August 2009, 03:31 AM   #1
Default Need advice on how to add multiplier to scale readout
Hello all, I want to build a 1/14th scale semi truck weigh scale. I need a way to make an electronic scale readout multiply the actual model weight by 2500. Example a 1/14th scale loaded model truck which weighs actual 32 lbs to read out as 80,000 and everything in between. 16 lbs would read out as 40,000 etc. Does anyone have any ideas on how I could acomplish this? Thankyou, Darwin
darnat46 is offline
Old 31st August 2009, 10:07 AM   #2
As it would make sense to be doing this using a microcontroller anyway, just do the multiplication in the software.
Old 31st August 2009, 10:01 PM   #3
LED or LCD digital displays are usually built around a full scale reading of 199.9 for an input voltage of 199.9mV. Take whatever signal you have coming from the "weigh circuit" and simply attenuate it with a resistive divider or gain it up using a non-inverting op-amp gain stage so that you get the scale range you want.
bountyhunter is offline
add, advice, multiplier, readout, scale
ADC readout to Decimal Kryten Micro Controllers 6 1st April 2008 07:25 AM
Scrolling readout on LCD? karenhornby Electronic Projects Design/Ideas/Reviews 0 4th March 2008 09:21 PM
frequency readout circuit mstechca General Electronics Chat 5 23rd April 2005 04:30 AM
4 bit shift and add BCD multiplier arjunarikeri Electronic Projects Design/Ideas/Reviews 6 29th March 2005 12:30 PM
Tachometer with LCD readout actionplus Electronic Projects Design/Ideas/Reviews 4 30th October 2003 09:28 PM
