Old 31st August 2009, 01:47 AM   #1
Default Question about LCD's
Hi, I wish to use a serial interface to an 5 digit position, 7 segment LCD. I am planning to use a 74HC595 serial-to-parallel shift registers. I am choosing these because the outputs can be latched. The outputs are also tri-state so my question is:
Do you think it is possible to alternate from high Z output back to latched data in unison with the back plane signal to get the LCD segments to display the correct data?
Space Varmint is offline
Old 31st August 2009, 02:05 AM   #2
LCDs need an AC style signal, DC latches are not good for them.
Bill
Smart Kits build Smart People
Old 31st August 2009, 02:13 AM   #3
No need to tristate the latches. Just drive the segments 180deg from the backplane when you want them on and 0deg when you want them off. A 30-60Hz backplane squarewave should work OK. So as long as your processor and serial interface can toggle the latches at that rate, you should be fine. As mentioned by BlueRoom, DC is a no-no for LCD direct drive.
kchriste is offline
Old 31st August 2009, 02:48 PM   #4
That's my point. I want to leave the data in the latches alone and toggle the tri-state and back plane. You know from high Z to driving.
Old 31st August 2009, 03:02 PM   #5
There are PIC microcontrollers with LCD drivers in them, easy to use too.
Bill
Old 31st August 2009, 04:18 PM   #6
IN THEM? I didn't know that. I have used their AY0438 but it's only 4 & 1/2 digits. I need 5. Well, thanks I will loo into that. Sounds better!
Old 31st August 2009, 04:23 PM   #7
Yea build in LCD controllers, set & forget. What were you planning to connect it to?
The 16F917 is a typical LCD PIC. It can control LCDs with up to 4 commons.
Bill
Old 31st August 2009, 04:47 PM   #8
Cool Blue! I'm looking at this one here:
http://ww1.microchip.com/downloads/e...Doc/41364B.pdf
I'm on page 393. I guess the SPDIP could be programmed on the PicKit 2? I would just need to make an adapter cable.
Yeah, I want to use the LCD section for a freq counter.
Old 31st August 2009, 08:13 PM   #9
Oh man, I am playing hell installing MPLAB v8.36
Old 31st August 2009, 08:30 PM   #10
The PK2 programs pretty much the entire line. If you search for my old cricket threads you'll find a schematic and code snip.
Bill
Old 31st August 2009, 08:53 PM   #11
Did you get a new adapter board like this 28 pin?
Product Search - microchipDIRECT
I guess I need new PicKit 2 software too. The '917 you used is 40 pins isn't it?
Old 31st August 2009, 08:56 PM   #12
Yes the 917 is a big chip, depending on your LCD you might be able to use a smaller PIC. Your PK2 simply connects to VPP,VDD,GND,PGD & PGC (all clearly labeled on the pinout for the 16F917) Just hook em up and you're good to program.
Bill
Old 31st August 2009, 09:26 PM   #13
Roger, got ya. So just make my own board from the 5 pins of the PicKit2 over to the chip? Because I didn't even see an adapter board for the 40 pin your using.
About your code. Is your handle "cricket" in the forums? Is that where I look? I'm definitely interested in your code.
Old 31st August 2009, 09:48 PM   #14
I use a 5x2 connector for my ICD connector. The 16F877A uses the same programming pins as the 16F917
They are the same order as the PK2s first 5 pins. Just make sure you have a 22k resistor from VPP (pin1) to VDD
Bill
Old 31st August 2009, 11:46 PM   #15
Yeah I see them here:
• ICSPCLK
• ICSPDAT
• MCLR/VPP
• VDD
• VSS
I think I want to use this PICLF1936. It's only 28 pins and comes in the slim DIP package. It has 60 segment controls where the PICF917 has 96. Your code is probably the same for both. You know how PICs are. Let me check your web page. Do you have a link to your code?
lcd, question
lcd's gugs Electronic Projects Design/Ideas/Reviews 1 3rd October 2008 01:11 PM
JunkYard LCD's - How to use them ?! TiagoSilva Micro Controllers 28 24th February 2006 09:36 PM
LCD's and ESD Overclocked Electronic Projects Design/Ideas/Reviews 7 29th December 2005 10:25 PM
LCD's, yes they work, but how ? Stressed_Eric General Electronics Chat 1 17th May 2004 07:53 PM
7-segment LCD's question! brodin General Electronics Chat 6 6th April 2004 10:59 PM
