Greeting, Can anyone recommend a output stage for transimpedance circuit using MOSFET? Thank you | |
what are you looking to do? I would use an op amp with a feedback resistor and take the output voltage that way. | |
Actually, it is CMOS MEMS circuit As show in the attachment, I am looking for the output stage for transimpedance in order to lower the output resistance. The output stage that I'm using is look like inverter(for digital circuit). Someone say it does not work, so I am looking for the other one. any suggestion please thank you | |
Seems to me you only need to bias the one you already have. You need to have both devices silghtly on when the input is zero. Otherwise, you'll have a huge deadban in your output.
__________________ You don't need a quadraphonic Blaupunkt -- you need a curve ball. | |
a comparator with a push pull output stage should work. Have you looked at one of these...? What current do you need to drive?
| | #6 |
the current comes from photo diode around 1uA and, is it possible to have output voltage around 1V (using 0.35 COMS process with L_max = 20um W_min = 0.4um) | |
| circuit, mosfet, output, recommend, stage, transimpedance |
| New guy here with a MOSFET question (as in recommend me one)... | kpatz | General Electronics Chat | 8 | 28th May 2009 11:56 PM |
| output stage of tda2030a | hentai | Electronic Projects Design/Ideas/Reviews | 10 | 18th May 2007 09:42 PM |
| Multi-stage MOSFET Amplifier design.. | cqbrules | Electronic Projects Design/Ideas/Reviews | 3 | 1st March 2005 09:44 PM |
| VHF Output Stage | riggd | Electronic Projects Design/Ideas/Reviews | 1 | 3rd November 2004 09:31 AM |
| How to design such output stage | eeglp | Electronic Projects Design/Ideas/Reviews | 4 | 8th April 2003 07:01 PM |
