Old 28th August 2009, 09:06 PM   #1
Default A slightly higher output voltage from a PIC
I want to switch a chip (low current) which requires an off signal of under 4.5v, and an on signal of over 5.5v. I need to do this for eight pins.
The first thing I thought of was an ULN2803 with pullup resistors, but that takes up a lot of room, and makes the board very complex. Are there any chips which will do this without the use of pullup resistors? I would like a chip with 8 switchers in it, which eliminates MOSFET drivers etc (although these seem like a waste as it is low speed, low current).
Any ideas of chips?
Summary:
Input: 8 TTL inputs
Output: 8 low/high outputs, high being close to VCC.
There is 9V and 5V power rails currently.
Many thanks!
Richard
Richard S is offline
Old 28th August 2009, 09:45 PM   #2
Unless I have missed something, what is wrong with powering an octal changeover analogue switch off the 9V rail and switching the logic inputs with your micro? Connect one side of the switch to your 9V, one side to ground and the common to the device you need to drive. Not sure if you can get octal changeovers, but 2 quads should be easy to get. take a look at Maxim or TI..
Bill Naylor
www.electronworks.co.uk
Electronic Kits for Education and Fun
Electronworks is offline
Old 28th August 2009, 09:57 PM   #3
That sounds like the solution - I just need to find one. Anyone got any suggestion (pref. Maxim)?
The device I want to control is two 4066s, running on 9v (so needing 5.5v for a logic 1).
Richard
Old 28th August 2009, 10:01 PM   #4
Then just use pullups and tris the output pin (portx = 0)
Bill
Smart Kits build Smart People
Old 28th August 2009, 10:17 PM   #5
I was hoping to find an IC with internal pullups = less wiring.
Richard
Old 28th August 2009, 10:23 PM   #6
Use a sip resistor.
Bill
Old 28th August 2009, 10:25 PM   #7
Good thinking.
I'm currently looking at Maxim's analogue switchers, instead of the 4066.
Richard
Old 28th August 2009, 10:27 PM   #8
I've chosen:
I'm going to go with MAX474-something. They are the same as the 4066, but can be driven directly from a PIC (1.8v is logic high).
Thanks for everyone's help!
Richard
higher, output, pic, slightly, voltage
AC adapter - higher than expected output voltage giftiger_wunsch General Electronics Chat 11 17th June 2009 02:25 AM
Ceramic Caps - Drawbacks to Higher Voltage Noggin General Electronics Chat 4 7th December 2008 04:04 PM
Using higher voltage in RC car regulator7812 General Electronics Chat 3 24th February 2008 03:59 PM
does every multimeter shows higher voltage mamun2a General Electronics Chat 12 29th November 2006 04:49 AM
R/C Receiver output voltage, suitable for PIC input?? Koetje General Electronics Chat 1 3rd August 2004 09:53 AM
