Old 27th August 2009, 04:24 PM   #1
Default question about dimmer
does ceiling fan dimmers (triac based speed controllers) reduce fan motor's lifetime?
aruna1 is offline
Old 27th August 2009, 04:44 PM   #2
The dimmers in fans are actually potentiometers. Every motor has a maximum currrent it can handle. If you limit the current, providing less and less current, the fan will go slower but the lifetime will go up. If you go over the current level, the lifetime shortens. It's just like an LED. On LED specs, you'll find something like 20,000 hours or 30,000 hours based on a specified current which is usually 20-30mA.
ElectroNerdy is offline
Old 27th August 2009, 05:05 PM   #3
well what i meant is triac or SCR based phase control dimmers
aruna1 is offline
Old 27th August 2009, 06:38 PM   #4
Anything that reduces current level will increase the lifetime.
Old 27th August 2009, 11:11 PM   #5
maybe they changed AC motors recently, but a rheostate (pot) "dimmer" to an AC induction motor won't work. Take the control guts down out of a three speed fan and you will find a selector switch and two capacitors:
speed 1 = cap 1
speed 2 = cap 2
speed 3 = cap 1+2
There is no pot. I did buy a fan a long time ago with a "solid state" speed controller with a pot and the motor failed along with the controller. If you starve the current going to an AC fan, the motor will eventually stall at a very abrupt point. That's how I have seen fan motors work. Running the motor slower (near stall) actually makes it get hotter.
bountyhunter is offline
Old 28th August 2009, 12:22 AM   #6
TRIAC based dimmers do not regulate current. They change the "duty cycle".
Yes aruna1, poorly designed, minimal parts dimmers DO reduce the life significantly - mainly via overheating of the fan coils as well as no "soft start".
vsmGuy is offline
dimmer, question
IR Light Dimmer fedail Electronic Projects Design/Ideas/Reviews 13 17th July 2009 06:47 AM
Dimmer sammy004 General Electronics Chat 40 23rd April 2008 12:06 AM
light dimmer Fahime Electronic Projects Design/Ideas/Reviews 4 19th September 2007 07:01 AM
2k watt dimmer rampage Electronic Projects Design/Ideas/Reviews 5 8th April 2007 11:40 AM
Dimmer circuit help subzero349 General Electronics Chat 1 25th July 2003 02:37 PM
