First, thanks for the help on my steering controller, got it working beautifully!! Now, I have a buggy that I need some assistance on the throttle control for when things get rough because of my disabilities. I took my Audiovox ccs100 apart and it has 3 air valves, 1 lets air out to the vacuum of the manifold to pull the diaphragm in and pull on the throttle cable, the other two let air in to relieve the vacuum on the diaphragm. At present, the safeties in the system drop the vacuum if the RPMs vary too much, which defeats what I bought it for. SO; what I want to do is control the valves to maintain a near constant RPM. I could use a Pot to set the desired speed and I would like to have a PID (proportional, integral, derivative) control. I will use the RPM signal for the tach as the input. My thoughts are to establish a voltage relative to the RPM to get an input voltage and use PWM to control the valves to let air out or in according to RPM. Does any one have in suggestions on how to set this up? Thanks Kinarfi Last edited by kinarfi; 24th August 2009 at 11:52 PM. | |
Here is the wave forms I have to work with at ~ 1800 RPM. I need to convert this to a DC voltage. How about a pointer in which way to go. Please Kinarfi | |
Have you thought about getting an electric cruise control module from a junk yard? I have one from a 95 Chevy Monte carlo that I parted out. It has a small servo motor to operate the throttle cable and all of the drive electronics. It also has a microcontroller for its brains (looks like an 8051). So it probably has the PID already built in. It may have the same rpm protection though. It may not, it would just about put the throttle to the floor when going up hill.
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
I already have the CSS100 and it looks like an LM2917 is just the ticket to convert my square wave from the ECM to a voltage, then can use the circuit that I created for my steering assist project to create my PWM to the air valves. The spec sheet has a diagram with proportional control and the diaphragm works slowly enough that I may not need anything else.
How about some suggestions folks, I need to be able to reference off of the square wave, maybe an RC circuit. Please
| control, kinarfi, project, throttle |
| Starter Motor Scooter - Throttle Help | MikeSingleton | Electronic Projects Design/Ideas/Reviews | 4 | 14th February 2009 10:23 AM |
| Sharing throttle position sensor signal | rayhall | General Electronics Chat | 6 | 6th December 2007 10:29 PM |
| a project that has to do with control and communication | genman4 | Electronic Projects Design/Ideas/Reviews | 3 | 25th January 2007 11:35 AM |
| Scooter Throttle Control | fantasymick | General Electronics Chat | 2 | 28th September 2004 02:36 AM |
| instrumentation and control project | iieeahmed | Electronic Projects Design/Ideas/Reviews | 1 | 13th January 2004 07:52 PM |
