Old 24th August 2009, 08:02 PM   #1
Default Building small stereo speaker w/ dual LM386 amp
Hello everyone. I've been working on a small project using 2 LM386's I purchased from Radioshack, because to the best of my knowledge an LM386 can only amplify one channel of audio. I want to build it in a small wooden enclose, and for it to operate off of battery power.
This is the circuit I used:
Chapter 10: Computers and Electronics
I have built 2 amplifier circuits already, but I still need to build the enclosure and mount them, etc.
For the battery power, I would like to operate off of a supercapacitor or the like. I don't want to shell out for dozens of 9V batteries, and I like the fast charging qualities of capacitors. I read an article about building your own 9v battery replacement, but the link was missing:
SuperCap 9V battery - Hack a Day
I have found a 1000uF 11V capacitor, and was wondering how I would go about stepping down the voltage. Would an inductor work for something like this, or should I go with an integrated solution? I would like it to be as efficient as possible without going over a $20 budget.
My estimate to the current requirements of the current circuits are about 250mA to 350mA, but I have not measured it yet. If it is required, I can do it.
jivix is offline
Old 25th August 2009, 09:12 AM   #2
Use batteries, NiMh so you can recharge them - Supercaps are really pretty useless for most purposes, and don't last very long.
A 1000uF might last a second or two, it's a LONG way short of been a Supercap.
Nigel Goodwin is online now
Old 25th August 2009, 06:10 PM   #3
The link to the project does not work.
A reader commented that a little AAA cell has 1000 times the capacity of a 11F super-cap. A 9V battery has six AAAA cells in series so it has the capacity of 500 super-caps.
A 9V alkaline battery has a capacity of 625mAh at a current of 25mA. A 9V Ni-MH rechargeable battery has a capacity of only 175mAh.
audioguru is offline
Old 25th August 2009, 11:17 PM   #4
And you can get AA "camera" type NIMH batteries all over the place that are 2000 mA-hr. Stack six and get a ton of power.
Even generic AA NI-MH are in the 1200 - 1400 mA-hr ballpark and you can find them cheap a lot of places. I see them at places like Harbor Freight tools for about $6 for a four pack.
bountyhunter is offline
Old 28th August 2009, 03:53 AM   #5
My bad, I overestimated the power of a Farad. I just graduated high school and I am going to start out in college. I took 3 years of engineering classes but we've only gone so far as watts/horsepower and not so much into joules and farads.
Is there any way for me to set up a super-durable (long lasting) rechargeable setup for this? From the looks of it so far there isn't any way to do it, save solar panels.
What about D batteries? How would I go about stepping up the voltage? Should I use one of those big dual-coil wraps that step up voltage, or should I do an electronic voltage stepper?
jivix is offline
Old 28th August 2009, 02:59 PM   #6
If you stepup the voltage of a single battery cell then its current increases the same amount so that its power output is what you want. So it won't last very long. Then you shoulld use six AAA or AA Ni-MH cells in series to make 9V instead.
Watch out for huge D cells. The one from Energizer is a big package with a little AA Ni-MH cell inside. Their C cell is the same.
Old 28th August 2009, 04:59 PM   #7
Ah but then why do C cells and D cells have different amounts of mA? Or was this change with Duracells very recent? According to This, "D" batteries have about 50% more capacity than "C" batteries. I have seen that they can also provide a significant amount of current at once, and they create some very potent electromagnets when tied up to a coil w/ steel rod. However, if it would be easier for me to stick with the 9V's, I suppose I will stick to them. I'd just rather not have to buy 2 9V batteries every time they die on me (as I would have one for each channel of audio, or have them parallel connected to both.) I will also be adding a power adapter to it in case I would like it plugged in. Will I have to add diodes to the 9V's to keep the adapter power from going through the batteries?
jivix is offline
Old 28th August 2009, 08:39 PM   #8
The AA in a C / D cell is mostly used with rechargeable batteries.
Bill
Smart Kits build Smart People
Old 29th August 2009, 01:10 AM   #9
Duracell is the name of a battery manufacturer, not the name of a certain type of battery.
Like every other battery maufacturer, Duracell makes throw-away alkaline batteries and Ni-MH rechargeable batteries. The datasheets on their website show that they are the same as every other battery manufacturer (except cheap Chinese ones).
Most products that are powered from a battery and an AC adapter use a jack with a built-in switch to disconnect the battery when the adapter is plugged in.
Old 29th August 2009, 02:58 AM   #10
I understand that Duracell is a company, I am talking about "D" cell batteries... the largest consumer cylinder cell they produce (for small electronics).
Yes, I know they have switches to keep the batteries safe when running on the DC adapter. What I am asking is, what method should I use to protect the batteries? The first thing that came to mind were diodes.
jivix is offline
Old 29th August 2009, 03:33 AM   #11
Some D-size Ni-MH rechargeable battery cells are cheap and lightweight. Because they have a little AA cell inside. A good D-cell is expensive and heavy because it is full of battery stuff.
You do not need a switch. You also don't need a diode.
The jack from the AC adapter has a built-in switch that disconnects the battery when the adapter is plugged in.
Old 29th August 2009, 05:51 AM   #12
I believe you will find the little cell inside of the fake D and C cells is actually called a sub-C cell. It's a bit smaller than a standard C cell. I have cut them open before, that's what was in there. Sub C cells are very cheap because hey are used in the hundreds of millions to power tools and consumer junk.
Old 29th August 2009, 02:07 PM   #13
Energizer sells Ni-MH AA and AAA cells that are made in Japan.
Their Ni-MH 9V battery is made in Germany.
Their cheap Ni-MH C and D cells are made in (guess where?). China.
They still make disposeable alkaline cells in the United States.
I don't know where their lithium cells are made.
Old 29th August 2009, 02:46 PM   #14
I used to use NiMh in my camera's but found that if not used soon, they loose charge within several weeks.
I have replaced all of my NiMh cells with Sanyo Eneloop cells.
These cells can sit for a year and still maintain about 85% of their charge.
If you are constantly using and recharging, the NiMh are fine, but I prefer the Sanyo eneloop cells for my usage.
PatM
http://malfam.googlepages.com/
PatM is offline
Old 29th August 2009, 02:56 PM   #15
Energizer's new AA Ni-MH cells also keep their charge for a long time. Maybe they are the Sanyo ones.
amp, amplifier, building, circuit, dual, lm386, small, speaker, stereo, volt, w or
Coax for 50 ft long stereo unit speaker wire? priscilla7391 Electronic Projects Design/Ideas/Reviews 5 28th March 2009 06:24 PM
Driving a Speaker: Op Amp or LM386? bugmenot General Electronics Chat 18 2nd March 2009 01:30 AM
Need assistance with stereo LM386 circuit men_with_ties Electronic Projects Design/Ideas/Reviews 2 14th February 2008 07:10 PM
LM386 speaker, woofer and tweeter adumas Electronic Projects Design/Ideas/Reviews 7 9th August 2007 09:49 PM
LM386 and DAC0832 with an 8-ohm speaker mdanh2002 Electronic Projects Design/Ideas/Reviews 16 13th April 2007 09:06 PM
