Old 20th August 2009, 09:38 AM   #1
Default Music analysis using DSP
I want do this as my BE project.
I guess it has to be done using MATLAB. The software should recognize the type of music that is being played, ie, is it a sad or happy music? Is the project feasible.....? and if yes can you please throw some light on the method of doing it...???
fubuaks is offline
Old 20th August 2009, 10:01 AM   #2
It is not possible to directly determine sad vrs happy. Instead you need to look a tempo and other things you can measurem, then create a set of rules to decide what is sad or happy.
I do not know how to do this.
3v0
BCHS/3v0's Tutorials
3v0 is offline
Old 20th August 2009, 11:40 AM   #3
Fine......so how can i measure the tempo.....???Is it same as bpm...??
fubuaks is offline
Old 20th August 2009, 12:23 PM   #4
There is work on recognizing facial expressions (happy, sad, angry, depressed, etc.) and maybe voice. I don't have any references, but recently saw some examples. Looking at the methods used there may give you some hints.
John
jpanhalt is offline
Old 20th August 2009, 04:35 PM   #5
Sounds incredibly ambitious but interesting. Simplifying as suggested would probably be a lot more feasible. BPM should give you tempo assuming you can figure out BPM from the music. e.g. how do you do this with, say, classical chamber music -- no drum? You may need to put some constraints in place to make it easier
Michael Shimniok
http://bot-thoughts.blogspot.com/
Microcontrollers can solve world hunger, too!
shimniok is offline
Old 20th August 2009, 04:41 PM   #6
Presumably this is a college project?, might be an idea to approach the music department to ask for suggestions how to do it?.
Old 20th August 2009, 06:06 PM   #7
You could just focus on Russian composers, like Shostakovich. Sad would be the default answer. Sousa would be happy; but what about American spirituals (e.g, Lena Horne) or Mozart's piano concerto #23. Can you get people to agree on whether they are happy or sad?
In reality, I think the real problem will be to define what is sad and what is happy. If humans can't agree on the mood, you will have an impossible time getting an instrument to make the decision.
Perhaps, if you can determine the key of the music with your analysis, that would be enough, but still plenty challenging.
John
jpanhalt is offline
Old 21st August 2009, 12:46 PM   #8
The first step in doing this is getting the tempo of the song, which is done by detecting the beats per minute. I've found a couple of algo's for this, but those were a bit complex.Can anybody provide me with a much simpler algo......??
fubuaks is offline
Old 21st August 2009, 01:02 PM   #9
As far as I'm aware, DSP is complicated - a much simpler one probably wouldn't work.
Old 21st August 2009, 01:09 PM   #10
M talking about dsp only, but by simpler i mean, in a bit simpler language.
fubuaks is offline
Old 21st August 2009, 02:07 PM   #11
It sounds like a good project.
You should take Computing, Maths and Music Technology A-levels, submit this as the project for each and kill three birds with one stone.
if I know the answer.
Hero999 is offline
Old 21st August 2009, 10:32 PM   #12
To start, see if you can determine tempo.
Then see if you can determine ratio of major to minor chords.
flat5 is offline
Old 24th August 2009, 06:32 PM   #13
Where ever i've searched, I've found the algo given in the foll. file has been used. But m finding it difficult to get hold of it. So can anybody help me understand it. The link of the file is:http://www.electro-tech-online.com/e...eirer_jasa.pdf
fubuaks is offline
Old 28th August 2009, 07:11 PM   #14
I've got some idea of how to find the tempo. Here i am listing the various steps-
1. Firstly the music has to be broken down into 6 bands of frequency,
2. then envelopes of all the six signals has to be constructed in time domain,
3. then the beats are to be found out by passing it thru a differentiator
4. and then finally the signals should be convolved with comb filter of different tempo's.
The first doubt is how do i break a sound signal in different subbands in matlab?
fubuaks is offline
analysis, dsp, music
music analogue circuit analysis ag General Electronics Chat 0 6th February 2009 04:18 PM
Dsp beenuseren Micro Controllers 0 21st May 2008 08:06 AM
can any one help me in DSP HiteshDR Datasheet/Parts Requests 10 8th November 2007 07:36 AM
DSP Help!!! microzone Electronic Projects Design/Ideas/Reviews 1 19th December 2005 06:23 AM
Any DSP expert here? french_student Electronic Projects Design/Ideas/Reviews 3 9th March 2004 07:26 PM
