+ Reply to Thread
Results 1 to 7 of 7
Thread: 555 Timer long off - short on times
  1. #1
    mrwizney Newbie
    Join Date
    Aug 2009
    Posts
    3
    Red face 555 Timer long off - short on times
    Greets all;
    Its been a while since I played with the 555 timer. I have got one to work with long time periods, years ago (yep, old fart now). Now I need an astable circuit that is on for 1 second, off for 60 seconds, or close to these times. I will figure it out eventually on my own, but I figure some of you are current with 555 timer applications, so I'll ask for your assistance and see what fly's.
    Thanx in advance for your help should you reply to this.
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,791
    Sorta close. The first pulse is slightly longer.
    Mike ML.
  3. #3
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,934
    What are you trying to do?
    If it's just flash an LED or power a relay then connect the load from the + rail to the output and the duty cycle will be automatically inverted.
    if I know the answer.
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,791
    Quote Originally Posted by Hero999 View Post
    Yes, but the first timing period is twice as long as the others, and since it the longer of the two periods, it is more noticable than the previous circuit.
    Mike ML.
  5. #5
    mrwizney Newbie
    Join Date
    Aug 2009
    Posts
    3
    Smile 555 Circuit values
    Hi again Mike;
    I ran some numbers on the circuit you suggested. And with some digging, I found pretty much the same circuit, but your suggestion just looks more reliable...
    Anyway, I used the following values and get the given signal specs as follows.
    R1 = 280K ohm
    R2 = 18.42M ohm
    C2 = 4.7uf not electrolytic
    Frequency = .016Hz
    Duty Cycle= 1.7%
    Time High = 1.008 Sec.
    Time Low = 60.014 Sec.
    If I may ask your opinion once again, do you see any problems with these parameters? I know the resistor values are not stock, other than that, do you think this is a stable configuration?
    Thanks again for allowing me to pick at your brains...
  6. #6
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,791
    For a bipolar 555, I like to keep the resistors below 5meg, and use larger capacitors.
    For a NE555, TI says keep the sum of the two resistors below 10meg. For a LM555, National says 20meg. The issue is that for an astable, the resistor has to supply the input leakage/bias current for TWO pins at once.
    If your relay coil draws less than ~200mA, you can drive it directly from the 555 (either way). If it draws more, you will have to add a transistor or Fet or buy a more sensitive relay.
    Mike ML.
  7. #7
    mrwizney Newbie
    Join Date
    Aug 2009
    Posts
    3
    Smile
    I thought there was some sort of limits that are the conventions. I was concerning myself about the timing cap. As I recall, it should not be an electrolytic because the stability of the timer is effected.
    Knowing these details, I will go back and try again, attempting to stay within those parameters. As for the relay, yes I am aware of that. I am using a transistor driver circuit anyway because at some future time, a larger relay may be employed. And I am aware of the need to select components that properly saturate the transistor... etc.
    Thanks again for your help...
+ Reply to Thread
  1. Need HELP in long delay 555 Timer
    By vincentspm in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th August 2009, 12:52 PM
  2. Long delay Timer
    By raindeepak4u in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th February 2009, 05:25 AM
  3. How can I get 3 volts to trigger a short circuit??(skateboard timer)
    By scuppers in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd March 2008, 11:46 AM
  4. short pulse ---> long hi signal
    By huttojb in forum General Electronics Chat
    Latest: 2nd June 2007, 12:57 AM
  5. need help on long duration timer
    By naren in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd November 2003, 12:23 PM
Tags for this Thread
