From reading some of these threads I am absolutely positive that you guys can help.
I am a RC plane nut. I practice mostly aerobatic sequences. One of the most important things about performing aerobatic maneuvers is that the plane be in a perfectly level attitude before the maneuver is performed. Its probably the most difficult aspect of aerobatics. The maneuvers themselves are basically easy to do. But to do them with good lines the wings must absolutely be level first. And from the ground flying determining if the wings are level is very difficult.
Here's what I would like to do. To help me with orientation I would like to install a tilt sensor of some sort accurate to 2-5 degrees at least that would light an LED light that is visible from the ground indicating when the wings are level. So, as I ready the plane for a maneuver I could glance at the area of the plane where the LED is to determine if it is level and if not correct for it. Even 3 LEDs would be great. One to indicate level and colored LEDs to indicate the need for left or right roll correction.
Soo...let's see what you guys got. I would need a walk through on what to purchase and how it should be wired as I have little to no electronics back round. Hope you guys are up to the challenge. The one who comes up with the most accurate, lightest weight , and least expensive solution to perform this task....gets.... Well nothing. A sincere thank you from yours truly.
