+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 23
Thread: Noise from preamp
  1. #1
    vsmGuy Okay
    Join Date
    Jun 2006
    Posts
    46
    Question Noise from preamp
    I just made a preamp for myself .. based on a LF351 I had lying around.
    I did not AC couple the output from the amp however.
    I get a constant noise at the background (like an Airconditioner heard from inside the room). We have central heating and I am sure the noise upstairs does not come down so much for the mic to pick up.
    Is it because of me not ac coupling the output?
    In that case .. would a 0.33uF polycarbonate be ok?
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    The old LF351 opamp is not a low noise audio opamp. Of course it will produce hissss.
    The output coupling capacitor has no effect at high hiss frequencies, its value affects the circuit's lowest bass frequency.
  3. #3
    vsmGuy Okay
    Join Date
    Jun 2006
    Posts
    46
    I was thinking maybe the constant DC output from the preamp was contriibuting to the noise .. can it be the cause?
    I seem to measure 2.5V with a cheap chinese coil meter even when I don't excite the electret. My Fluke measures ~1.7v but that keeps on changing. I am connecting this directly to the "mic in" of my laptop (I don't have a line level input)
    If the output CD offset can never be a cause for the "hiss", should I replace the thing with a TL074? (The TL071 seems to be much more expensive - both are fronm TI - why?)
  4. #4
    Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Schematic?
    Curiosity was framed. Ignorance killed the cat.
  5. #5
    bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent bountyhunter Excellent
    Join Date
    Jul 2009
    Posts
    726
    The LF351/356 J-FET op amps are very good amps for LINE LEVEL audio applications where 0 dB signal levels are pretty high. For microphone or phono pre-amps, they are not good enough. The best amp used to be the Signetics 5532 type, don't know if they are still the best, but they are very good.
    http://www.datasheetcatalog.org/data...nts/ne5532.pdf
    The other source of hum in low level amps is magnetic flux: is there a transformer within 12" of your amplifier circuitry?
  6. #6
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,043
    I don't see audioguru's problem with the LF351, it might not be as good as the TL071 but it's perfectly acceptable for most applications. If you're got plenty LF351s in your junk box then I don't think it's worth ordering new parts, especially if it's not part of a larger order.
    if I know the answer.
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    The complaint is that the LF351 produces noise in the preamp circuit. A better opamp made for low level audio will not produce noise.
  8. #8
    marcbarker Good marcbarker Good marcbarker Good
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    Maybe the circuit is 'hooting' @ few 100 kHz? (due to bad layout maybe)
    "I think, therefore I toast" ( Mr. T. Toaster, artificial life form, kitchen appliance & Philosopher)
  9. #9
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,043
    I think it's more likely to be a ground loop problem or the lack of shielded audio cable than the op-amp.
  10. #10
    vsmGuy Okay
    Join Date
    Jun 2006
    Posts
    46
    Aw, you guys made me draw a schematic. It was the usual stuff you know.
    It's powered from a 9V PSU (7809).
    Analog electronics is not my forte, so here is the schematic.
    The input is twin wire unshielded, but the mic is 6'' away from the opamp input.
    The output is a moulded stereo jack cable, the usual stuff.
    Op amp is not decoupled (the input power supply is suitably bypassed) and the pins shown not connected in the schematic are not connected.
    The schematic is truly the "true picture" of what I have... maybe I got some resistor values wrong from what it really is in my build, but I will have a closer look in the morning.
    Should I upload a few audio samples?
  11. #11
    vsmGuy Okay
    Join Date
    Jun 2006
    Posts
    46
    Quote Originally Posted by bountyhunter View Post
    I had just bought a lotta 351's. Got a few TL071 with me but they are reserved for some "better" experiments :-)
    There are no Transformers within 12 inches, but I connect my mic to a laptop , although it has a SMPS but no transformer to be sure.
    How do I find if the noise is injected from within the opamp, picked up be leads or is ambient noise just amplified by the preamp?
  12. #12
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    Disconnect one end of C1 and see if hiss stops.
  13. #13
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    I'd try removing the 9V power supply connection from between the input and the input cap. Seems to me that any ripple on the supply will also be amplified and, if it's full-wave rectified, that would make it 120Hz--which might sound a lot like an air conditioner.
    Simple idea to test and prove or disprove one way or the other, at any rate.
    Torben
  14. #14
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    The opamp is inverting with an input impedance that is so low that it shorts the signal from the mic. The opamp should be non-inverting with a high input impedance.
    The 1k resistor that powers the mic injects noise from the power supply that is amplified by the opamp. This resistor should be 10k and be decoupled with a 1k resistor in series from the supply and a 47uf capacitor to ground as a filter.
    The mic is low level so should be connected to the preamp with shielded audio cable.
    We are guessing that the noise is hiss or is hum. What is it?
  15. #15
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Quote Originally Posted by audioguru View Post
    Oops--I had missed where the OP mentioned that it was a preamp for an electret mic. My bad. Audioguru's suggestion then makes much more sense than mine.
    Torben
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Preamp Help
    By BigE4u in forum General Electronics Chat
    Latest: 11th June 2009, 02:21 AM
  2. help in a mic preamp
    By wakeke in forum Electronic Projects Design/Ideas/Reviews
    Latest: 31st December 2008, 06:38 PM
  3. preamp to amp
    By crivoli in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd May 2006, 04:14 AM
  4. looking for preamp
    By aguiluz in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th February 2005, 03:28 AM
  5. preamp with alc/help
    By Aleks999 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th July 2004, 09:50 PM
Tags for this Thread
