+ Reply to Thread
Results 1 to 4 of 4
Thread: Two 7-Segment LED's counting pulses.
  1. #1
    mabender Newbie
    Join Date
    Aug 2009
    Posts
    2
    Default Two 7-Segment LED's counting pulses.
    Hi guys. I am new here, and have experience in electronics, but not circuitry.
    Here is the scenario. The transmission control unit on my car sends 12v pulses to a diagnostics pin. You get 2 digit trouble codes by hooking up an led to the pin and to ground. You count long led pulses to get 1x, 2x, etc. The short pulses follow to get x1, x2, etc. For example, it will give 5 long pulses with half a second in between, wait a second or so, then give 4 short pulses with a half second in between. This equivalates to a data trouble code of 54.
    Instead of hooking up an LED to the pin, can I hook up two 7 segment led's with a proper driver? If so, how would I go about doing this? I am guessing I will need an input latch to lock the first segment led after the long pulses, then activate the second segment led to count the short pulses.
    Any feedback would be appreciated. I tried searching around and couldn't quite find exactly what I was looking for.
    Thanks. Mike.
    Edit: Parts I was thinking of so far
    500 ohm resistors
    HCF40110 counter/decoder/latch/driver
    radioshack 7 segment led's
    button to reset
    I think my big question is how do I make it switch from one driver to the next after the long pulses are done, and the small ones are about to start?
  2. #2
    kpatz Good kpatz Good
    Join Date
    May 2009
    Location
    NH
    Posts
    305
    It'll be easier to get a code reader at an auto parts store... but if you want to build something, I'd use a microcontroller. So much easier, at least if you know how to program them.
  3. #3
    birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    The delay in between makes this sound like the job for a microcontroller...
    Mike
    My website: www.ElectroBird.net
  4. #4
    mabender Newbie
    Join Date
    Aug 2009
    Posts
    2
    I'll take a look into the microcontrollers. I could just buy one, but I want to market them since there isn't anything out there to read the codes. The way these cars are wired, the typical scanners only read a few of the major codes, not all of them.
    Thanks for the replies though.
+ Reply to Thread
  1. multiplexing several(i.e 8) 7 segment 4-digit LED's
    By anurag2700 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th June 2009, 07:41 AM
  2. Counting lighting strikes---need to count pulses
    By qrper in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th March 2009, 03:22 PM
  3. Counting Pulses To Calculate RPM
    By Hasan in forum Micro Controllers
    Latest: 24th November 2003, 12:25 PM
  4. Counting In Coming Pulses on controller
    By waqar in forum Micro Controllers
    Latest: 19th May 2003, 12:21 AM
  5. counting pulses, comparing numbering digits
    Latest: 18th March 2003, 02:28 PM
Tags for this Thread
