+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 29
Thread: Diy guitar ebow
  1. #1
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    Default Diy guitar ebow
    does any one know if you go into this circuit like an amp or do you just connect if to a battery and hold it over the pickup of a guitar.
    http://www.logosfoundation.org/elektron/ebow_amp.gif
    Also are the coil sizes critical?
  2. #2
    Blueteeth Good Blueteeth Good Blueteeth Good
    Join Date
    Oct 2003
    Location
    Hertfordshire, UK
    Posts
    691
    Quote Originally Posted by Mdkanz View Post
    It's an e-bow, that means you hold it over the strings. I believe it is battery powered. If you plug it into your amp...would cause issues (would overdrive the input with whatever the coil pickups, probably mains hum).
    Its pretty simple, picks up the vibration of the string using the 'pickup coil', amplifies this using a power amp in positive feedback configuration, then drives a second coil, which vibrates the string. I would have thought the pick-up coild would be a coil surrounded a permenant magnet, so it can pickup the vibrating strings (air coil would do sod all)
    The circuit looks easy, the hard part will be putting it in an enclosure that can be easily used by a guitarist...and finding the optimal position/configuration of the coils. I say experiment!
    Might even have a bash at building one myself..perhaps making it over complicated by adding a distance sensing circuit
    Blueteeth
    Inconsistency is the key to flexibility!
  3. #3
    marcbarker Good marcbarker Good marcbarker Good
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    This is really neat! I think I'll make one and try on my Gibo LP!
    Can get audio transformers out of discarded cordless telephone.
    "I think, therefore I toast" ( Mr. T. Toaster, artificial life form, kitchen appliance & Philosopher)
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    Doesn't it just make continuous feedback sustained?
  5. #5
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    I understand what to use for the input transformer but i don't understand the output one. could someone explain what transformer to use for the output.
    Also i could not have a 1N4002 would a 1N4003 work?
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    Also I could not have a 1N4002 would a 1N4003 work?
    The input is not a transformer. It is a telephone pickup coil.
    The output is the "E" laminations and coil from a transformer with the "I" laminations removed so it projects a magnetic field to the strings.
    A 1N4003 is exactly the same as a 1N4002 except it survives a higher reverse voltage. It is fine.
  7. #7
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    What are ''E'' and ''I'' Laminations?
  8. #8
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    They are the iron core strips. The wire is wound on the center prong of the E and the I closes the magnetic loop. You want to remove the I iron strips (laminations) so that the magnetic field can escape to the guitar strings.
  9. #9
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    Quote Originally Posted by audioguru View Post
    Good explanation AG!
  10. #10
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    Thanks, what 2 out of the 5 wires do i connect the amp to? (Would this transformer work? http://www.radioshack.com/product/in...ductId=2103254)
    Also does any one know how to play the guitar with it? do you touch one of the coils and hold the other one over the pickup? do you touch both on the strings? do you pluck the string first then touch the ebow on it...
    and is there a way to test the amp without the coils to make sure it works?
  11. #11
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    Thanks, what 2 out of the 5 wires do i connect the amp to? (Would this transformer work? Audio Output Transformer - RadioShack.com)
    It's worth a try. I have a good feeling about that transformer if it helps.
    No idea what wires, just use trial and error. I think you'll need some permanant magnetism somewhere as well.
    I tried an e-bow in my local music shop when they first came out in early 80's, I didn't buy it because it was too expensive for what it was. It was just before MIDI synths came out. You just hold it over the strings instead of picking, the movement of it towards the stringa starts the bowing. Makes a different harmonics depending how near the bridge.
  12. #12
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    ok, i took a part a cordless phone i got at a thrift store and the pickup (i'm assuming that is the part you talk into) is two little black 1'' diameter mics is that what you are supposed to use? the speaker looks more like what i was imagining it is aboutt 2'' diameter would it work?
    What did you mean by this?
  13. #13
    Join Date
    Jul 2009
    Location
    London, UK
    Posts
    728
    look for one of these inside it.
    and remove the 'I's to leave behind the 'E' + windings
    Maybe you can hack the earphone out the phone and/or use that too?
    by magnetism, I mean something to make the strings detectable. There's also a magnet in the pickup.
  14. #14
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    The telephone pickup coil is a recording accessory and is not part of a telephone. It picks up the magnetic field of the earphone of a telephone.
  15. #15
    Mdkanz Newbie
    Join Date
    Mar 2009
    Posts
    77
    OK, i built the whole thing exactly how it said to and it 1/2 way works. it will sustain (but not infinite) it if i pluck the string then put the pickup up to the string and the transformer kind of under the string really close to the coil any ideas? also i thought ebows are supposed to change the sound this just sustains the normal noise.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Guitar Amp Help
    By wooz in forum Repairing Consumer Electronics
    Latest: 30th October 2009, 12:54 PM
  2. Guitar Pre-amp
    By apakhira in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th June 2006, 09:14 PM
  3. Guitar amp IC
    By Fletcher in forum Datasheet/Parts Requests
    Latest: 31st March 2006, 05:04 PM
  4. Guitar to PC?
    By elMickotanko in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th March 2004, 06:15 PM
  5. Acoustic guitar amp VS Guitar amp
    By Johnson777717 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd February 2004, 02:16 AM
Tags for this Thread
