that's a good question... I just noticed the physical dimensions of these devices, and I don't like my chances of being able to solder something 2.9mm in length with pins 0.95mm apart
Since I haven't yet got myself an etching tray, etc. which I would need to make my own PCBs, I was planning on building these circuits on stripboard. Clearly even if I could solder such a small device (and I have little experience in soldering) I would need to be able to make a suitable PCB as well.
The devices suggested by marcbarker seemed to be appropriate, though perhaps I should check the dimensions in the datasheet for those items as well...
, they could work under a microscope and assemble prototype surface mount circuits, using bits of copper-clad blank PCB and these funny self-adhesive surface mount IC footprint bases, all wired up with almost hair-thin enamelled copper wires.
I thought the transistors are activated by the current from base to emitter, or the voltage between gate and source in the case of MOS-FETs... how can they be activated by the motor current?
