+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: K8004 problem with PWM controller noise
  1. #1
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    Default K8004 problem with PWM controller noise
    I have a problem with PWM controller.
    I use velleman K8004 PWM controller card to drive DC motor. I have a problem that when I choose low frequency (by rotating resistor) the motor vibrates, when I set high frequency (5000Hz) I hear high pitch whine noise.
    Is it possible to make the noise inaudible?
    Manual:
    http://www.velleman.be/downloads/0/i...k8004_rev3.pdf
  2. #2
    Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    You need to change the components in the oscillator section...C3 and R3....try making C3 around 22nf
    Making the frequency around 18khz will make it inaudible
    Eccentric millionaire financed by 'er indoors
  3. #3
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    So I should change C3 form 100nF to 22nF. And the resistor change to what?
    Won't it bother my cat?
  4. #4
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    Quote Originally Posted by smilem View Post
    So I should change C3 from 100nF to 22nF. And the resistor change to what?
    Make one change at a time....Change the capacitor first and see if that makes it better....Leave the resistor as is for now...
    Put the cat outside...
  5. #5
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    Quote Originally Posted by Chippie View Post
    Well, changing the capacitor improves it but I still can hear it a bit myself, don't know about the cat
    What lower value I can try because the higher the frequency the lower the torque of the motor, I mean it has less power right?
  6. #6
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    You'll have to experiment unitl you find a cap that doesnt affect your hearing.....or else change the value of the 2k2 resistor by half...The effect of that would be to reduce the charging time for the cap so the RC time constant is shorter and the frequency should go up...
    You could always wear earmuffs....
  7. #7
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    Thanks, is it normal that the FET is dead cold, and SG IC chip is a bit warm, doesn't it require a heatsink?
  8. #8
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    The fet may warm up depending on the load current it is switching...
    as for the chip....shouldnt get too hot...You could add a small dip heatsink if you wanted...
  9. #9
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    thanks for help
  10. #10
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    To get stable motor speed do I need to use LM338 or can I just use A diode bridge with transformer as power source?
    Also isn't is possible to calculate the required frequency?
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,771
    18kHz is easily heard by young people who are not deaf.
  12. #12
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    So do I need to feed this circuit from LM or it will work fine simply by using diode bridge with capacitor?
  13. #13
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    Have a look at figures a,b, and c in the manual
  14. #14
    smilem Newbie
    Join Date
    Feb 2009
    Posts
    98
    The manual lists: 8-35VDC unregulated and figure A shows a simple diode bridge with capacitor as power source. But since I use configuration C that shows internal reference voltage used as control coltage. This means if my DC current is unstabilized by LM338 the motor speed will change as voltage changes right?
    I will use slowest motor rotation mode possible so that means that LM338 is a must no?
  15. #15
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    If you use figure C, just connect a potentiometer value 1k as per the drawing, using Vref,
    connect your dc power supply as shown, the motor speed is then controlled by the new 1k pot....
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. problem with noise generation
    By mpradhan1 in forum General Electronics Chat
    Latest: 25th February 2009, 11:53 AM
  2. Op Amp output noise Problem
    By Lighty in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th February 2009, 06:41 PM
  3. problem with Mr. noise
    By HAMZAZAYYAD in forum Micro Controllers
    Latest: 22nd January 2006, 03:42 AM
  4. AM band noise from motor and/or controller
    By Lil_Guppy in forum General Electronics Chat
    Latest: 28th February 2005, 12:07 PM
  5. Jewellery scale noise problem
    By anil_asdaq in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th December 2004, 01:45 PM
Tags for this Thread
