Old 11th July 2009, 01:59 AM   #16
KIA6903P IC for speed control of general purpose DC motors. controls by detecting back emf of DC motor. Only needs this IC plus a 75 ohm and a 1 k pot.
http://www.datasheetcatalog.org/data...c/KIA6903P.pdf
marcbarker is offline
Old 11th July 2009, 07:11 AM   #17
Originally Posted by marcbarker View Post
That's for a two-wire PM DC motor right? How does measuring the motor current determine how much voltage to apply?
I always thought that circular shaped circuit board inside the motor was a voltage regulator, with an adjustment pot below the hole to trim the speed.
Just as a sanity check, I connected an ordinary DC PM motor to a variable-voltage supply here, the RPM is proportional to set voltage. The RPM doesn't change by much when loading the spindle. When the loading on the spindle makes the current exceed the power supply limit, then the revs drop. I suspect the voltage is dropping.
The RPM does in fact change though, and in some systems this is undesirable.
Basically you measure Va, Ia, and knowing Ra the calculation for the
back emf is:
Vb=Va-Ia*Ra
This is then subtracted from a reference voltage Vr that sets the speed,
and the error voltage is then amplified and integrated and that sets
the new Va. That forms the complete feedback system. The final
value of the system w(inf) is Vr/Kb, which means constant w.
In the above:
Va is the armature voltage (measured)
Ia is the armature current (measured)
Ra is the armature DC resistance
Vb is the back emf
Kb is a constant of the motor
Rotational inertia is ignored.
MrAl is offline
Old 11th July 2009, 02:36 PM   #18
I've 'scoped the current waveform through a small cheap Chinese DC motor at different voltages to change the speed.
The 'scope was set to AC, the current was measured by connected a 1Ω resistor in series with the motor. One division represents 50mA on all waveforms.
1) 3V 2ms/div
2) 6V 2ms/div
3) 9V 1ms/div
4) 12V 0.5ms/div
Sorry about my shaky photography, my hand isn't that steady and the waveform wasn't always stable.
Assuming the motor is three pole, what's the speed?
DC motor, consistent speed under different loads?-3v-2ms-d.jpg   DC motor, consistent speed under different loads?-6v-2ms-d.jpg   DC motor, consistent speed under different loads?-9v-1ms-d.jpg
if I know the answer.
Hero999 is offline
Old 11th July 2009, 02:38 PM   #19
It'll only alow three attachments per post, so here's the last one.
Hero999 is offline
Old 11th July 2009, 04:18 PM   #20
After you deduct for I*R loss voltage is directly proportional to speed and current is directly proportional to torque.
Kinarfi
kinarfi is offline
Old 11th July 2009, 04:34 PM   #21
Yes I see what you mean now.
By my rough reckoning, @ 3 V = 5000 rpm
6 V = 10,000
9 V = 16,000
12 V = 19,000
Did by chance see of the RPM changed much with loading?
Old 11th July 2009, 04:47 PM   #22
You're right.
I make it about 17000rpm@9V but it isn't easy to count the squares due to my shaky photography.
I make it 3.5 squares giving a period of 3.5ms, 60/0.0035 = 17,148rpm.
I'll see if I can count the pulses with my frequency counter, it might give be triple the frequency but I'll easily be able to figure that out.
Yes, the frequency does change with loading.
This is probably the simplest method of measuring the speed of a DC motor, it's fully compatible with PLL. It can also be made to be compatible with PWM, if a filter is added to get rid of the PWM, making what is essentially a buck converter.
Hero999 is offline
Old 11th July 2009, 07:24 PM   #23
Here's a better picture at 9V.
I've also noticed that the waveform changes when the motor is run in reverse which indicates that the motor isn't completely symmetrical. This normally happens because of the ways the brushes wear when the motor is normally only operated in one direction.
1) Better picture, 9V 1ms/div, 50mA/div
2) Waveform when connected in reverse, same 'scope settings as #1.
I've tried using a frequency counter but it didn't work. I measured a frequency of 30kHz which seemed to increase when I put a load on the motor. The counter is probably triggering at a harmonic and is changing when a load is applied (the waveform also changes shape when loaded). I tried adding a low pass RC filter 680R and 100nF but it didn't work. I also tried a 22µF capacitor in parallel with the motor and a common mode EMC choke to no avail.
The motor emits some pretty high frequency RF harmonics: I accidentally connected it to the 20MHz to 1.3GHz counter input and it read 300MHz which explains the TV and radio interferance generated by it. The harmonics probably extend well into the microwave band.
Hero999 is offline
Old 11th July 2009, 09:05 PM   #24
Yes, the arc when the commutator switches is going to generate all kinds of stuff.
It might be hard to filter out because the filter has to have wide bandwidth too.
Maybe mount an antenna next to the motor to pick up the RF bursts, then count
them (chuckle) :-)
Maybe high pass would help pick out the arc over points.
The back emf technique BTW has been used on various tape recording machines.
It's not perfect but it does work.
Hall effect sensors have also been used very effectively and there isnt much
of a problem with noise.
MrAl is offline
Old 11th July 2009, 10:35 PM   #25
them (chuckle) :-)
Good point. Looking at the waveforms, maybe get a good signal for freq counter by differentiating out that very fast edge I can see there on all the traces. Maybe try first putting the counter input probe near, but not touching, to try this out first.
I reckon differentiated pulse could be buffered up with a capacitively coupled 74HCsomething gate connected in linear mode (you know, with some neg feeback round it).
Of course with a brushless motor it's really easy to interface to one of the phases.
Old 11th July 2009, 11:59 PM   #26
My previous post was supposed to have attachments.
Here they are:
With suitable filtering and Schmitt trigger such a system could easily be used with a PLL to form a very stable motor controller.
I've tried connecting an 8Ω speaker in series with a small DC motor before and it emitted sound proportional to the speed of the motor. Obviously the speaker will blow if it was connected for too long, with a load on the motor, to get round this an LM386 amplifier and speaker could be connected to the sense resistor. This could be used in a remote controlled car or robot for an engine sound.
DC motor, consistent speed under different loads?-9v-1ms-better.jpg   DC motor, consistent speed under different loads?-9v-1ms-reverse.jpg
Hero999 is offline
Old 12th July 2009, 08:15 AM   #27
Hey, that's better :-)
MrAl is offline
consistent, loads, motor, speed
Motor Speed? diablo1 Robotics Chat 1 18th January 2009 04:46 AM
Speed Control Of Dc Motor nelson_kh Robotics Chat 25 5th January 2008 12:13 PM
motor speed: Please Help mortuzahasan Electronic Projects Design/Ideas/Reviews 1 16th February 2007 10:55 PM
engine speed controller (not the same as 'motor speed' post takemetotheriver Electronic Projects Design/Ideas/Reviews 0 6th February 2006 11:02 PM
AC motor speed control RubberDucky General Electronics Chat 3 10th December 2004 06:08 PM
