Old 8th July 2009, 11:58 PM   #1
Question Hall Sensor that Outputs High @ Bop
I need help finding a Hall sensor that outputs high when ON to drive a PhotoMOS. I've spent several hours pouring through Digi-Key, Jameco, and Mouser. All I find available in individual quantities are sensors that output low. The only workaround I can think of is to get a hex inverter, but I don't have a whole lot of room in my application.
My power source is +5V DC, 100 mA max load. The sensor can be ominpolar or unipolar. I just need it to turn on in the presence of a magnetic field. The PhotoMOS, driven by the output of the sensor, will be used as a switch to close a circuit. I'm open to other ideas for implementation as well.
mxm is offline
Old 9th July 2009, 12:02 AM   #2
A simple transistor can invert the output.
Bill
Smart Kits build Smart People
Old 9th July 2009, 01:03 AM   #3
Wow, thanks for the quick response. Will this do? http://www.rohm.com/products/databoo...f/dtc144ee.pdf
mxm is offline
Old 9th July 2009, 01:06 AM   #4
I grabbed some from Futurlec not too long ago, they act as a button when the magnetic field is near, if you apply a 'high' voltage it will be a high output when triggered
Mike
My website: www.ElectroBird.net
birdman0_o is offline
Old 9th July 2009, 01:16 AM   #5
Thanks Mike, I did check Futurelec as well, and what I found there was an Allegro 3503 that still had an output null voltage (B = 0 G) at one half the supply voltage. I'm afraid that might be too much and still drive the PhotoMOS on. In my application, I need the PhotoMOS off when the magnet moves away from the sensor.
mxm is offline
Old 9th July 2009, 02:05 AM   #6
My mistake! In my head a Hall sensor was a Reed sensor, I guess a Reed sensor doesnt apply to your project?
Mike
bop, hall, high, outputs, sensor
Hall Effect Sensor davidbball13 General Electronics Chat 4 4th September 2008 11:43 PM
Hall Effect Sensor gramo Micro Controllers 14 21st April 2007 01:49 PM
What type of Hall Effect sensor is cheap and common? for rotation sensor with magnet. William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 2 30th November 2006 07:59 AM
Hall Effect Sensor bryan1 General Electronics Chat 1 16th September 2005 09:21 AM
hall effect sensor koyeh182 Electronic Projects Design/Ideas/Reviews 5 26th December 2003 03:12 AM
