Help with thermistor and hot/cold alarm.
12 Last »
  1. #1
    JB_ JB_ is offline
    Woo hoo..just found this forum and it might just be what i'm looking for
    Check this site. It's a frost alarm to close/open a relay when things get cold, but what i want to do is reverse this and have it operate when things get hot, typically above 30-35 degrees. Its hopefully going to be used to start a fan running when the air inside my pc gets above that temperature and stop itself when the air reaches a low enough temperature. But only having a fairly rudimentary knowledge of electronics, not beginner, but not advanced, i dont know the correct thermistor to replace the 15k one. If indeed this would be neccesary, if anyone can help then i'd be most grateful.
  2. #2
    mechie mechie is offline
    Super Moderator
    High Temperature Alarm
    Welcome JB_
    Still using the 15k thermistor (Maplin part No. FX22Y) ...
    Swap the thermistor and 100k preset potentiometer for each other (so thermistor goes from 0v to op-amp input, 100k preset goes from op-amp input to 12v supply.
    This will reverse the sense of the circuit so the relay will energise for a high temperature.
    :idea: I would also suggest swapping the 100 preset for a 4k7 resistor in series with a 22k preset. This will allow the operating temperature to be adjusted somewhere between 10deg C with the preset at maximum resistance to 50deg C with the preset at minimum resistance.
    I believe such a resistor should have been shown in the original circuit [a design error ?] - if the preset was set to min resistance the thermistor would be connected directly across the supply lines. ops:
    0
  3. Thread Starter #3
    JB_ JB_ is offline
    Thanks very much, i'll go buy me bits tomorrow and try it out
    0
  4. Thread Starter #4
    JB_ JB_ is offline
    Works a treat, thanks very much that man. If i ever see you about i'll buy you a drink.
    /me buys fake beard, hat and glasses 8)
    0
  5. #5
    bryan bryan is offline
    How could the circuit be modified to allow for a large hysteresis, say 5-10 degrees?
    0
  6. #6
    ljcox ljcox is offline
    The hystersis is set by the 270 k feedback resistor.
    Reduce it to increase the hystersis.
    Len
    0
  7. #7
    Thanks, but how much would I need to reduce the resistance, to achieve a hysteresis of 10 degrees. Ballpark?
    Quote Originally Posted by ljcox
    Len
    0
  8. #8
    I can't answer that question unless you tell me how much the resistance of the thermistor changes when the temp changes by 10 degrees.
    Post that info and I'll do the calculation for you.
    Len
    0
  9. #9
    Thanks Len:
    If you can provide the calculations I would be happy to do the math. I will play around with the thermistor tonight and post tomorrow in any event.
    0
  10. #10
    Quote Originally Posted by bryan
    Thanks Len:
    I asked the wrong question yesterday. Instead of asking for the thermistor resistance change, I should have asked for the voltage change (for a 10 degree temp change) at the negative input to the Op Amp.
    With the existing feedback resistor (270k), the positive threshold will be about 6 + 0.22/2 = 6.11 Volt (see the 270k entry in the table below). The negative threshold will be about 6 - 0.22/2 = 5.89 Volt.
    So, I suggest you use the table below to determine feedback resistor you need for the 10 degree hystersis. ie. determine how much the voltage changes when the temp changes by 10 degrees and select the Rf from the table.
    Hystersis (Vh) for various values of Rf (currently 270 k)
    Rf Vh Rf Vh Rf Vh
    560 0.11 150 0.39 47 1.15
    470 0.13 120 0.48 39 1.36
    390 0.15 100 0.57 33 1.58
    330 0.18 82 0.69 27 1.88
    270 0.22 75 0.75 22 2.22
    220 0.27 68 0.82 18 2.61
    180 0.32 56 0.98 15 3.00
    k Ohm Volt k Ohm Volt k Ohm Volt
    0
12 Last »
5 Zone Alarm System ElectroMaster Electronic Projects 25 6th February 2007, 02:42 AM
Alarm Display Project loranimal Electronic Projects Design/Ideas/Reviews 4 19th March 2005, 05:14 PM
Need A Simple Alarm Clock Circuit Handiplus Electronic Projects Design/Ideas/Reviews 0 29th March 2004, 02:02 PM
alarm with resistor andrew2022 Electronic Projects Design/Ideas/Reviews 4 23rd March 2004, 05:08 PM
i need a circuit diagram of pic based alarm system.. BurhanUnalmis Microcontrollers 0 26th April 2003, 02:44 PM
Page Time: 0.07706 seconds      Memory: 7,642 KB      Queries: 16      Templates: 0
