Old 7th July 2009, 10:03 AM   #1
Default TTL to PPL coverter
I need a circuit or IC which can convert two phase Encoder signal with 5V to 24V with frequency about 1Mhz,
Would you please provide with something can perform that.
Thank you in advance
I’m from Syrian Arab Republic where lots of guys are trying to do better in electronics.
TronicBrain is offline
Old 7th July 2009, 12:58 PM   #2
Let me see if I understand. You want to convert a pair of TTL signals from a rotary encoder that swing between 0V and 5V (TTL levels) into a pair of signals that swing between 0V and 24V at a frequency of 1 MHz.
The last requirement eliminates the use of a comparator like the LM339 or LM393. A modern comparator with an open collector output might be a candidate but I don't have a part number in mind. The idea would be to run the output from the encoder to one input, and use a voltage divider on the other input to set the threshold. The output would need a pullup resistor to +24V. The comparator will need a pretty big slew rate to keep up with a 1 MHz. signal.
Second choice would be a single transistor inverting level shifter. This would be a common emitter switch. You need to make sure that you pull the base up to +5V when the TTL output is high since a TTL gate will not source muuch current. When the TTL gate goes low it will sink plenty of current.
We never have time to do it right; but we always have time to do it over.
Papabravo is online now
coverter, ppl, ttl
spi to rs232 coverter nikolai_dlsu Micro Controllers 8 7th February 2009 09:05 PM
12v to 1.5v coverter ferez Electronic Projects Design/Ideas/Reviews 14 24th November 2007 08:07 PM
