Old 6th July 2009, 12:03 PM   #1
Default Sinusoidal Phase Shift
I am trying to phase shift a sinusoidal signal by a small amount (a degree or two), I am aware I could do this with some ADC and microprocessor. However I would like to do it with some simpler analogue electronics, I have been looking at an "all-pass filter", however my signal will have a varying frequency and therfore this will not work as an "all-pass filter" will only work for a certain frequency. Any ideas?
Any help would be much appriciated?
Thanks,
Mark
meastwood98 is offline
Old 6th July 2009, 12:48 PM   #2
Thanks,
Mark
hi Mark,
What are the frequency limits, min/max and how 'accurate'.??
ericgibbs is offline
Old 6th July 2009, 01:15 PM   #3
Minimum frequency = 1Hz
Maximum frequency = 100Hz
I would estimate an accuracy of half a degree would be sufficient however i could probably work with a value worse than this.
If you need any more info, let me know.
Thanks,
Mark
Old 6th July 2009, 01:39 PM   #4
This very simple circuit accepts a 0.5Vpk sinewave signal and shifts it a few degrees.
Over the range of 100Hz thru 1KHz the phase shift does vary a little.
Do you use the LTspice simulator.?
Old 6th July 2009, 01:53 PM   #5
No, i use NI multisim to simulate circuits. Would it be possible to modify the circuit to run it from a 5v supply?
Old 6th July 2009, 01:56 PM   #6
It should be OK at +5V, the output swing will be reduced.
Give it a try,,, the value of the 820R changes the amount of shift, try a few different values.
Lets know how it goes.
Old 6th July 2009, 02:16 PM   #7
Sorry, I fogot to mention my signal is a sinusoid that has an offset, its magnitude is 1.2v pk-pk and is offset 2.5v. That circuit works fine for a signal with no offset, can it be modified to work with my signal?
Thanks,
Mark
Old 6th July 2009, 03:04 PM   #8
Thanks,
Mark
hi Mark,
Is that a 'dc' offset of 2.5V.? , ie: its a 1.2Vppk superimposed on +2.5Vdc level.?
Can you post your Sim circuit.?
Old 6th July 2009, 03:08 PM   #9
Yes so the peak value is 3.1v and the trough is 1.9v, I dont have a sim circuit, I just built up your circuit to test it.
Old 6th July 2009, 03:10 PM   #10
OK, I'll re-look at it.
Old 6th July 2009, 04:08 PM   #11
hi Mark,
Just sims OK.
The images are for 1KHz, 500Hz and 100Hz[ with the cct].
The 2nd stage is bring the output to the same level as the input, if required.
Note the fairly high output impedance.
Sinusoidal Phase Shift-aaaimage03.gif   Sinusoidal Phase Shift-aaaimage05.gif   Sinusoidal Phase Shift-aaaimage06.gif
Old 7th July 2009, 11:27 AM   #12
From my simulation of the circuit the phase shift is dependant on frequency, are you sure you didnt adjust the value of R when testing it at different frequencies?
Old 7th July 2009, 11:37 AM   #13
No I didnt.
Old 7th July 2009, 11:40 AM   #14
Ok. Any ideas to where im going wrong?
Old 7th July 2009, 11:56 AM   #15
I have just re-run the sim, this time using a sweep freq, same results as the ones I posted.
Please post the simulation details and circuit that you are using, also with some details of the changes being observed.
phase, shift, sinusoidal
Phase shift - Phase Angle windozeuser General Electronics Chat 20 20th March 2009 10:39 AM
phase shift mayeewa General Electronics Chat 1 27th September 2008 10:40 AM
Phase Shift Search it Electronic Projects Design/Ideas/Reviews 2 5th September 2008 02:13 PM
Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave Qaiphyx General Electronics Chat 20 21st July 2008 02:37 PM
How Can I detect the phase shift between two sinusoidal signals Abdullah2121 Electronic Projects Design/Ideas/Reviews 13 1st April 2008 04:37 AM
