| | #16 |
My apologies, the circuit does work at 100Hz, 500Hz and 1kHz. However when i reduce the frequency to 10Hz, the phase shift increases. Is this the same with your simulation? Thanks | |
| | #17 | ||
This was your reply to my post asking for limits. Quote:
![]() EDIT: I see what I have done wrong, I have misread 1HZ as 1KHZ!!!, what a plonker, very sorry about that. I will beat my self with a pain stick for 10 minutes.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2009 at 01:05 PM. | |||
| | #18 |
hi, See my edit. I will rework the circuit to suit 1HZ and 100Hz limits, get back to you.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2009 at 12:48 PM. | |
| | #19 |
hi, At these low frequencies the size of the capacitors makes this technique not a feasible method. From about 10Hz thru 100Hz the coupling caps are 1000uF and the phase shift is only just acceptable, less than 10Hz the phase shift is not acceptable. I'll think of an alternative solution, let you know the outcome. EDIT: Can you say what is the application is for this phase shifted signal, ie: whats the end result.?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2009 at 01:09 PM. | |
| | #20 |
We have a linear sensor that gives out two sinusoidal signals 90 degrees apart, these are put through an interpolator (which we cannot play with the electronics inside) and then into a PC for Transmission Error Measurement. The problem we are facing is a large error on the PC, which is caused by the two signals not being exactly 90 degrees apart. There is approximately 2-3 degrees of error.
| | #21 | |
Thanks for the explanation, I'm still kicking myself for misreading your posted limits.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #22 | |
If linearizing the interpolation requires phase-shifting one of the quadrature signals relative to the other, this becomes a trivial operation once the signals are digitized. I'll bet that the interpolation is no more complicated than a vector multiply. | ||
| | #23 |
The problem is that the interpolator and the computer software is something that is a permanent setup that we use with various different linear and rotarty encoders. Therefore the solution we want is to be able to just plug the sensors in as we would with an encoder without editing any software or the interpolator. The sensors themselves only cost approx £5 and therefore cannot really be expected to give the same accuracy as an expensive encoder, however we were just interested if we could manipulate the signals to get somewhere close. If it cant be done its not a problem, thanks anyway. | |
| phase, shift, sinusoidal |
| Phase shift - Phase Angle | windozeuser | General Electronics Chat | 20 | 20th March 2009 10:39 AM |
| phase shift | mayeewa | General Electronics Chat | 1 | 27th September 2008 10:40 AM |
| Phase Shift | Search it | Electronic Projects Design/Ideas/Reviews | 2 | 5th September 2008 02:13 PM |
| Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave | Qaiphyx | General Electronics Chat | 20 | 21st July 2008 02:37 PM |
| How Can I detect the phase shift between two sinusoidal signals | Abdullah2121 | Electronic Projects Design/Ideas/Reviews | 13 | 1st April 2008 04:37 AM |
