I am trying to make a cicuitboard for my circuit which is prototypes on the breadboard. There are serial port Tx and Rx pins from a PIC16f688 which i use to interface to the PC. On the breadboard these work fine, when i soldered these onto my board the trasmission has a lot of errors. I have checked the connections and I am using wires to solder these onto the board. Is there a recommended way of soldering when a serial transmission is concernced. What can be done to prevent these errors. Best Regards and TIA. Sumit | |
You have to use a MAX232 to get the correct voltage levels, if you want to connect your PIC to a RS232 port.
| | #3 | |
Besides, if I'm interpreting the OP's post correctly, this used to work while his circuit was on a bread board, but it began not working properly when he built a permanent circuit. My guess is that there is a missing ground between the computer's serial port and the circuit. The PIC Vss pin has to be wired the computer's ground (pin 5 on the serial port?). Last edited by MikeMl; 5th July 2009 at 07:14 AM. | ||
If it is connected the same on both the breadboard and the soldered board then it could be your solder joints. It may be worth reading Basic Soldering & Desoldering Guide Mike. | |
| serial communication, solder |
| Soldering issue... | polbit | Electronic Projects Design/Ideas/Reviews | 11 | 1st December 2008 04:38 AM |
| Quick RS232 Connection Question | speakerguy79 | Micro Controllers | 2 | 6th November 2008 04:41 AM |
| Unused RS232 Pins for other connection | Urahara | Micro Controllers | 3 | 3rd October 2008 11:37 AM |
| RS232 connection | shahramxyz | Electronic Projects Design/Ideas/Reviews | 0 | 24th September 2005 09:05 AM |
| PC serial port connection | Spectacular Butter | General Electronics Chat | 2 | 5th March 2005 12:18 AM |
