Old 7th July 2009, 12:32 PM   #16
I've no idea why you insist on using a pic. If you had a look at the circuit I posted above, you'd see that your task is very simple using a single 555.
Anyway, for a pic12F508, the following code should work. Use MPASM to assemble.
#include "p12f508.inc"
	__CONFIG _MCLRE_OFF & _WDT_OFF &_IntRC_OSC
	radix dec
inpin 	equ 0
outpin 	equ 1
sec90	equ	10
cnta	equ 11
cntb	equ 12
cntc	equ 13
	org 0
start:
	movlw	0
	option
	movlw 	255-(1<<outpin)
	tris 	GPIO
main:
	btfsc	GPIO,inpin		; wait for inpin low
	goto	main
	call	delay
	btfsc	GPIO,inpin		; make sure inpin is actually low
	goto	main
waitloop90:
	bsf		GPIO,outpin		; output high
	call	delay
	incf	sec90			; 1 second has passed
	btfss	GPIO,inpin
	clrf	sec90			; reset count if inpin is still low
	movfw	sec90			; test for 90 seconds past
	xorwf	90
	btfss	STATUS,Z		; quit after 90 seconds
	goto	waitloop90		; otherwise keep going
	bcf		GPIO,outpin		; reset output
	goto	main
; delay for a second
delay:
	movlw	6
	movwf	cntc
dloop0:
	movlw	216
	movwf	cntb
dloop1:
	clrf	cnta
dloop2:
	decfsz	cnta
	goto	dloop2
	decfsz	cntb
	goto	dloop1
	decfsz	cntc
	goto	dloop0
	retlw 	0
	END
dougy83 is offline
Old 7th July 2009, 12:55 PM   #17
Default He can't see the forrest because
all the trees are in the way
KEEP IT SIMPLE!
use the 555/556 circuit I posted
It works in multisim so it should? work for your app.
BUT learn something
BREAD BOARD the circuit then discover how and why it works.
Your opening yourself up for failure by getting the simple task to complex.
MrDEB is online now
Old 7th July 2009, 02:44 PM   #18
I use PICs to improve my programming "skills". The more i work with them, the more macros or canned programs i collect.
I only suggest one way to solve the problem. A 555 is a good simple way to solve the problem. There are other ways depending on what parts you have on hand.
Enjoy the challange!
Larry
larrybeaty is offline
circuit, hold, input, pic, relay, removed
What would be the minumum PWM frequency to hold a relay? blueroomelectronics Electronic Projects Design/Ideas/Reviews 22 15th February 2008 11:41 PM
Unreferenced function removed MizuRyuu Micro Controllers 4 24th July 2007 08:32 PM
Need for sample and hold circuit microcare General Electronics Chat 5 24th July 2007 05:41 PM
Evil Genius Forum Removed ElectroMaster Feedback/Comments 5 7th June 2005 01:17 AM
Problem on telephon hold circuit..... smorteza Electronic Projects Design/Ideas/Reviews 3 14th March 2004 03:22 AM
