| | #16 |
| | #17 |
I think model airplane xmitters & receivers is better than walky talkies. They are a one way system. You don't need to pay for a two way system. They are easy to adapt/modify for your purpose. Walkies, not so much. They should have the range you require. | |
| | #18 |
to build from scratch or a kit or ready to use? here are some circuits that may do what you want but will require some work. radio remote control RC using DTMF circuit diagram Electronic Kits, Circuits and Projects FM Transmitters«RF«Circuits/Schematics Directory Radio Remote Control using DTMF « Transmitters « RF « Circuits/Schematics Directory walkie talkies was just a suggestion for an easy way to get the job done. while not ideal but would work. would still need to add DTMF circuits. hope this helps | |
| | #19 |
RXD433 transmitter receiver modules
| | #20 |
| Do you think you could build this project and if so how m ford79pu5@aol.com | |
| | #21 |
I am not the best when it comes to RF circuits. the DTMF is no problem. Also how fast do you want this? If you can't locate someone else then maybe. | |
| | #22 |
Why do I bother?
| | #23 |
you couldn't find someone more qualified my suggestion is use a 2 way radio then connect a DTMF module to them. If you can't find someone then yes I will build you a unit. the easiest circuit (parts location?) is radio remote control RC using DTMF circuit diagram | |
| | #24 |
Model airplan/car/etc transmitters etc might be the easy way to go. Tried locating DTMF vhips etc but really no luck. Then it hit me- why reinvent the wheel? Get a simple 1 or 2 channel RC transmitter receiver then attach a micro switch or ? to the start gate then when the gate opens the transmitter sends a signal to the receiver and BAM you start the stopwatch. couldn't be simpler. Look on Ebay for used transmitter/ receiver sets | |
| on or off, stopwatch, wireless |
| Stopwatch Schematic | 7404 quad2 input | Electronic Projects Design/Ideas/Reviews | 9 | 25th April 2009 08:29 PM |
| LCD stopwatch to LED ? | Pyromaniac | Electronic Projects Design/Ideas/Reviews | 2 | 19th October 2008 11:29 AM |
| Designing stopwatch with 16f887 | matlark | Micro Controllers | 13 | 7th June 2008 12:19 AM |
| Building a stopwatch with PIC16F877a | ag501 | Electronic Projects Design/Ideas/Reviews | 23 | 8th January 2008 04:19 PM |
| Automatic timing with a stopwatch | Ybody | Electronic Projects Design/Ideas/Reviews | 0 | 3rd June 2003 01:02 AM |
