Old 2nd July 2009, 04:32 PM   #1
Default Help Needed with SCUBA Light Switch Circuit
I am building a SCUBA torch using a piezo switch (these work well underwater) and two LED heads.
The sequence I am after is;
First press...LED 1 on,
Second press... both LED 1 & 2 on.
Third press...both off.
The circuit in my current torch has only one LED and uses a 555timer to toggle the LED on/off via the piezo. The 555 output operates a FET allowing 1amp to flow.
Do I need to source a programmed chip or can this circuit be made using ordinary non-programmable parts?
Regards
Mac
Klemheist is offline
Old 2nd July 2009, 05:05 PM   #2
The ckt can be made of ordinary non-programmed parts. You're describing the operation of a simple binary counter. Look up binary counter circuits before going thru the complexity of using a programmed solution.
BTW, I'm a diver too!
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 3rd July 2009, 12:20 AM   #3
Default SCUBA Torch Ongoing
Brownout
Thanks for that,
I thought as much but my expertise extends to soldering and sourcing parts, not designing the actual circuit.
Here's a couple of pictures of two existing torches we've made using MR16 size tripple CREE XR-E LED's by Terralux, in a converted Maglite head. One uses a piezo and the other a magnetic reed swich array. Both with the same 556 toggle circuit.
Batteries are 2-cells of 4*18650 Li-ion's + protection circuit. About 5Ah of capacity on a 3watt draw. Doubling this should still give enough for two dives before needing top re-open for re-charge/change.
If I can get something as compact as the existing switch circuit arrangement that will save on unwanted buoyancy.
Any help on the circuit detail most appreciated.
Cheers
Klem
Help Needed with SCUBA Light Switch Circuit-concept-torch.jpg   Help Needed with SCUBA Light Switch Circuit-blinder-mkii.jpg   Help Needed with SCUBA Light Switch Circuit-torch-battery.jpg
Old 3rd July 2009, 03:24 AM   #4
Hi klemheist,
here is a circuit not quite to your desire, but may be you'll like it.
The functions are:
LED1 - ON, LED2 - ON, LED1 + LED2 - ON, ALL OFF
I hope it fits into your enclosure without changes to the design.
R5 and R6 are calculated for white LEDs with 3.5V forward voltage and 20mA forward current.
More info on the attached files.
Boncuk
Boncuk is offline
Old 3rd July 2009, 04:47 AM   #5
Just in case the PCB is too large, here is an SMD-version with dimensions 0.91875X0.65inches.
Boncuk
Boncuk is offline
Old 3rd July 2009, 04:55 AM   #6
Default Dive torch ongoing
Boncuk,
Thanks for that, this is exactly what I am after.
No, I don't think space will be a problem. It looks a similar number of components to our existing single-LED toggle circuits (see photo).
On that. Do you think I can take the two outputs from your 4027 Flip Flop and instead of them activating transistors have them activate a FET instead?
Our current switch circuit uses a logic FET like the IRLZ34N to power these 3Watt LEDs. I was advised that logic FETs allow them to open completely when you want them too, with minimal resitance and copes well with the high current.
One more question. I am unsure what the acronyms at the top of your circuit mean; "S1-I, S1-O" and the four to the top right, "D2, D1". I assume they mean Switch One Input and Output but don't know the others. Are these necessary in my case?
Also, unsure what the line between the 6V symbol and Ground is ('IC 1P').
Klem
Help Needed with SCUBA Light Switch Circuit-toggle-circuit-revised.jpg   Help Needed with SCUBA Light Switch Circuit-toggle-circuit-photo-.jpg
Old 3rd July 2009, 05:09 AM   #7
Boncuk,
Thanks also for the circuit design. As you can see I buy one of these project boards and tyr and figure out how to solder wires connecting it all up.
I know I should get into PCB building and etching but have never really found the time. Any starter advice here would be welcome
Klem
Old 3rd July 2009, 06:34 AM   #8
How much pressure is needed to activate your touch switch? How deep do you plan on diving to? 32 feet is 1 ATM.
Pay it forward.
Mikebits is offline
Old 3rd July 2009, 06:57 AM   #9
Hi Klem,
since the switch and the LEDs are not located on the PCB the labels and solder pads are used to connect the switch and the LEDs.
S1-I and S1-O are connected to the switch. In the schematic both, switch and LEDs are dummies for better understanding.
+D1 and D1- as well as +D2 and D2- are connected to LED1 and LED2 respectively. (+ = anode, - = cathode)
IC1 P (IC1 Power) represents the supply pins of IC1, which can be identified looking at the pin numbers (8 for ground and 16 for VDD).
I will redesign the circuit for power MosFets.
According to the schematic you posted that circuit allows only one LED to be switched.
Boncuk
Boncuk is offline
Old 3rd July 2009, 09:36 AM   #10
Default SCUBA Toggle Switch circuit ongoing
Boncuk,
OK, understood on the solder pads....makes perfect sense now.
Yes, our existing toggle circuit is an on/off for one LED only, but necessary when using a non-mechanical momentary switch like a piezo. I included the photo to show the size and where we're at as far as expertise (or lack of it!) is concerned.
Klem
Old 3rd July 2009, 10:10 AM   #11
Mikebits,
Yes, pressure is an issue with torch switches underwater and you are right to point this out. You need a switch that handles up to 5 atmospheres. From 1 atmosphere at the surface to at least the limit of diving on air...50metres, 6 atmospheres.
As you allude, diving is a harsh and unforgiving environment on electrical equipment. normal mechanical toggle switches work with waterproof rubber boots, but they are high profile and prone to getting knocked or the rubber pierced.
Commercial torches use mechanical switches going through a waterproof O ring to the inside
Press toggle on/off switches are useless as they become permanently compressed underwater with the pressure. So a reverse clicky toggle never goes on and a forward clicky toggle is constantly on.
Another method is to use a magnetic reed switch, either with the magnet applied for the entire dive or use a toggle circuit like in this thread with a momentary swipe. obviously normal reed switches are amps limited so you have to have some sort of relay system happening for the high amps needed. reeds are fragile to the knocks and bumps so be careful but they do help with the 'hull integrity' and are low profile.
Finally there is the more expensive piezo option with a toggle circuit. We've dived to 45 using piezo switches with no problems. As the ambient pressure increases and decreases on the piezo it is gradual enough that it doesn't respond like an intended activation. It works just as well at 45metres as it does on the surface.
attached are photos of different switches we have used. Some with more success than others.
It's a constant journey of discovery
Cheers
klem
Help Needed with SCUBA Light Switch Circuit-complete.jpg   Help Needed with SCUBA Light Switch Circuit-new-array.jpg   Help Needed with SCUBA Light Switch Circuit-punisher-ii-upgrade.jpg   Help Needed with SCUBA Light Switch Circuit-imgp0767.png   Help Needed with SCUBA Light Switch Circuit-imgp4064.jpg
Old 3rd July 2009, 12:04 PM   #12
Hi Mike,
ATM is out, bar is in!
Boncuk is offline
Old 4th July 2009, 04:28 AM   #13
Hi Klem,
I've changed the design to use two IRLZ34 transistors.
Making the PCB using SMD components the board size will increase considerably since the transistors have D2Pak packages which require quite some space on the PCB even if one is mounted on the solder side.
Using discrete wired parts the PCB dimensions have slightly increased in length only. The overall height above PCB is approximately 15mm due to the TO262 packages of the transistors.
The TerraLux CREE XR-E can be operated at 1000mA max. The design stays well below the max value with 978.72mA at UB +6V (not considering RDSON of the MosFets) For less current change the values of R5 through R8.
Also, I don't understand the problem concerning push button operation in a submerged torch. You can use any pushbutton with an operating pin having at least 5mm length. Use the latex cover (102 bubbles) of a spill proof PC-keyboard and mount the pushbutton underneath adding a spring strong enough for the water depth you are planning for. (See attached sketch). For safer operation you might add a retainer ring at the top of the operating pin.
Also attached are thre PDF files of the circuit. If you are going to make PCBs you are welcome to receive the Eagle files via email.
Regards
Boncuk
Boncuk is offline
Old 6th July 2009, 08:21 AM   #14
Default Dual LED SCUBA Switching Circuit
Hi Boncuk,
Thanks again for that.
I've printed out all three files you sent and stared at them for the last 45 minutes. I see how you have rotated the larger FETs to save space and board width, plus thickened the tracks in parts...no wasted space...very nice!
It's not much larger than the earlier BC547 board at all. This is terrific for when we start looking to fit it inside the 50mm tube.
One question. I see Pin 8 on the IC4027 is connected to Ground on the circuit-board diagram, however is not shown on the main circuit diagram. Should this be the case, or left unused like Pin 15.
With your push-button switch query, you are of course correct, in that they can work underwater with the right amount of stiffness in the waterproof boot. Or as you allude the height is longer than the diameter (pressure from the sides more than pressure from top). This photo I showed earlier is a 'marine' momentary starter button, used in conjunction with a toggle circuit. It's the big black rubber button top-right. I remember diving to 20 metres with this design and the switch remained uncompressed by ambient pressure until you activated it. What didn't work however was the permanent seal arrangement. It had a couple of gelcel 12V battery's encased inside a 100mm PVC pipe with no access ports to aid waterproofing. Battery re-charging was via 2 brass bolts (one seen in the photo). These were kept from salt-water short-circuiting by a reed switch (also seen in photo).
Trouble is, the gelcel batteries didn't like being constantly deep-cycle drained and eventually they wore out, and on opening the terminals were all corroded and the reed switch semi-fused by high-amp charging exceeding it's rating. It was about to break down from any of those reasons but the battery was first. It was an early design...but, the switch did work fine.
These marine switches are fairly cheap also, and the rubber bomb-proof.
Cheers
Klem
Help Needed with SCUBA Light Switch Circuit-imgp0764.png   Help Needed with SCUBA Light Switch Circuit-imgp0767.png
Old 6th July 2009, 01:45 PM   #15
Hi Klem,
first off I wonder why you didn't mention pin16 (VDD) of the HEF4027. Together with pin8 it makes the power supply for that IC.
The power supply is the first item in the schematic on the left labelled 'IC1 P', meaning IC1 Power.
Pin15 is not connected on purpose since it's logic level is opposite of pin14's level, meaning if pin14 is high pin15 is low and vice versa.
By the number of experiments you have done so far I guess you'd be better off making an underwater floodlight of acrylic glass with the battery (SLA 6V/5.7Ah) and everything else encapsuled to make it 100% waterproof and deep sea going.
Acrylic glass is easy to handle and can be glued using the kind of glue camper manufacturers do. Basically it is acetone with a an additive of arsenic.
Using acrylic with 10mm thickness you will be able to dive to 100m without breaking it (provided the enclosure is not too big, or slightly arc the material applying heat) To make it safe you might equalize the inside pressure close to ambient pressure by inflating a baloon inside. (just the opposite of aircraft pressurization)
Further you can drill 'threaded sack holes' into it to mount any fixture inside.
In the meanwhile I have thought about the SMD-version, since the wired version is considerably high requiring lots of space.
The newly designed SMD-version has dimensions of 1.35X0.7625inches, using power MosFets type ZXMN05B14 (Zetex semiconductors), and available at Mouser for 31Cent each.
Even the IRLZ34 as D2Pak is 2,000% overkill for the load you intend to drive.
The mentioned transistor can drive loads up to 3.2A (still 320% overkill) and is available with an SOT23 package.
Kind regards
Boncuk
Boncuk is offline
circuit, light, needed, scuba, switch
leds light up circuit needed? cestudent Electronic Projects Design/Ideas/Reviews 7 27th November 2008 09:28 PM
LED christmas light switch (what would you call a circuit like this?) Andy1845c General Electronics Chat 14 1st December 2007 04:24 PM
MC Brake Light - Circuit Help Needed I-See Electronic Projects Design/Ideas/Reviews 4 16th February 2007 03:28 AM
Traffic Light circuit design help needed? MrCrowley Electronic Projects Design/Ideas/Reviews 2 5th December 2003 07:07 AM
LIGHT CIRCUIT HELP NEEDED RON Electronic Projects Design/Ideas/Reviews 4 24th August 2003 08:56 PM
