Old 6th July 2009, 05:59 PM   #16
Default SCUBA switch
Boncuk,
Yes, Pin 8/16, power points... I see it now. Understood.
We do use Perspex (acrylic) lenses.
Perpsex has slightly higher light transferability than Lexan (polycarbonate). Glass, even tempered glass is too brittle for pressure diving. I can buy Perspex sheets for $20AU from our local glaziers.
Initially we used thick 6mm tempered glass, but after a flooding at 20M when one cracked we've gone to Perspex for the strength and flex. The only drawback is it's prone to melting or browning/burning if it gets too hot. For this reason we try not to turn on the big HIDs until we get underwater
We use different torches for different diving.
Night diving is the most critical. We carry two each. A main 35Watt HID for long-range focussed light, and a mask mounted LED for reading console instruments and working close.
Daytime diving we carry one light only...The larger LEDs I have been talking about, for compact under-ledge/cave illumination.
The photo is my 35W HID night torch, which has a 100mm diameter 10mm thick Perspex lens. Powered by two 5Ah 18650 Li-ion packs (12 batteries), at 3.5A gives 120mins-140mins (depending on battery quality) continuous light of about 2,500+ lumens, 5,000K light colour. Reflector is collimated so it's a true spotlight. The ballast is mounted outside the waterproof Otterbox where the water can cool it (it gets hot). The igniter is inside. Essentially these HIDs are sold as replacement vehicle headlights.
LED's are about 500 lumens, but far more compact. For the LED's, using an old Maglite torch using 10mm perspex is a bit too thick for the available bezel thread. We cut a 50mm disk and spin it in a lathe to cut a 'step'. The 10mm lens at the edge becomes a more usable 5mm. At 50mm diameter there is less surface area to flex under pressure so we are less concerned with catastrophic failure than the larger lights.
We try for around 5000+K colour temperature. This 'white' light is far more natural underwater than the 'dirty' yellow that incandescents give (around 3,500K).
I'm heading into RS Components to pick up the 4027's tomorrow. It may take a while as I need to order another LED head from the States. I'll post photos of the torch build as I go.
Cheers
Klem
Help Needed with SCUBA Light Switch Circuit-punisher-ii-upgrade.jpg   Help Needed with SCUBA Light Switch Circuit-imgp4053.jpg   Help Needed with SCUBA Light Switch Circuit-imgp4235.jpg
Klemheist is offline
Old 10th July 2009, 06:23 AM   #17
Default Glass under pressure
Guys,
You were interested in the unforgiving nature of salt-water under pressure, so I tracked down this page;
Dive light - Mac's Prawn Punisher I
It's a photo sequence on another blog of what happened to an earlier design of SCUBA torch
The 6mm tempered glass lasted until about 20 meters depth and then broke. That was when we started using Perspex.
DIY underwater torches...an expensive hobby
Klem
(Boncuk, RS stuffed up the order and so I'm still waiting for the FETs).
Old 17th July 2009, 10:03 AM   #18
Default Test circuit made
Boncuk,
Still waiting on the FET's so I've built a test circuit in the meantime with your circuit. It works prefectly.
I applied 8V and measured the voltage straight off the 470 resistors and got the following toggle sequence;
1. Both on (8V)
2. Both Off
3. A only
4. B only
Terrific!
I'll post again later when the torch is assembled
Cheers
Klem
Old 17th July 2009, 01:29 PM   #19
Hi Klem,
from my understanding it doesn't work perfectly yet.
I added a power up reset cap (resistor was already present) and now the sequence is as I planned:
1. all off
2. LED1 on
3. LED2 on
4. LED1 and 2 on
5. all off (again)
Please check the schematic and locate C3 (1µF electrolytic cap) connected between V+ and the clock input of IC1A.
This way the circuit is reset upon power up with no LED lit.
C3 offers an additional feature, since it limits the pushbutton trigger intervals with pauses of 400 to 500ms. (might be useful when trying to blind a shark, not inadvertantly switching off all LEDs in panic )
With this IC you won't need a power switch (main switch) for the battery. When no LED is switched on the circuit draws 120nA of current. When powering the circuit up initially the current flow is about 5mA for 1/2 second.
The PCB has become 0.1inch longer than the preceeding one.
Regards
Boncuk
Boncuk is online now
Old 17th July 2009, 05:04 PM   #20
Default 1uF
Boncuk,
OK I'll give that a go
Nearest I have on hand at home is a 16V 10uF Electrolytic so I'll run by the store Monday
I can see the utility of not having the torch coming immediately on when you attach your battery pack. Saves immediately pressing the switch to turn it off.
Klem
Old 11th August 2009, 08:17 AM   #21
Hi Boncuk,
I finally got round to building a test bed with all components of your original circuit (without the 1uF capacitor you recommended recently).
I'm using 2 LED modules, similar to what I will be using in the finished torch.
On applying the battery pack both LEDs immediately come on.
Then LED 1 only (pin 2 from the flip flop)
Then LED 2 only (pin 14 flip flop)
Then both on again
There is no 'both-off' in the switching sequence
This 3-part sequence continues with each momentary switch
I then introduced a 2u2 tantalum capacitor (I don't have a 1uF on hand) as in your ammended suggestion and nothing worked
No damage, as when I removed it was back to the 3-part sequence again.
Obviously we need to be able to have a both-off as there's only one momentary piezo switch on the torch
Can you advise please?
Klem
Help Needed with SCUBA Light Switch Circuit-test-bed-1.jpg   Help Needed with SCUBA Light Switch Circuit-test-bed-2.jpg
Old 11th August 2009, 08:34 AM   #22
Bon Bon sure is a nice fella isn't he ? Way to go Bonman
Pay it forward.
Mikebits is offline
Old 11th August 2009, 08:36 AM   #23
Klem do you do night diving that requires the lamp? I only night dived once and I did not like it, I felt trapped in a box. Scared the crap out of me.
Pay it forward.
Mikebits is offline
Old 11th August 2009, 08:46 AM   #24
Have you seen the dive mask with lamps built in? one on each side of the head, They look very cool. I suppose the cost is high though.
Pay it forward.
Mikebits is offline
Old 13th August 2009, 05:31 AM   #25
Mikebits,
I like diving at night. makes a welcome change. We catch prawns here off the coast and in the river and also diffeerent fish come out at night. as long as you have a main spotlight and a back-up 'instrument' light (usually a small one hanging on side of facemask) there's no probs.
I find it quite peaceful actually
Listen, if you can provide someadvice on this earlier circuit diagram Boncuk sent would be most appreciated. just looking for someone to explain to a neandathal like me why there is no 'off' setting in the sequence with my rendering of his 4027 flip flop diagram.
cheers
Klem
Old 6th October 2009, 07:06 PM   #26
Klemheist
I am building a dive light using 4 Cree r2s, aspheric lens and a Kaidomain P7 2.8 amp driver, I want to use the same piezo switch I used with the Genie,
Just a simple on and off can you describe a simple circuit for that use.
Girdles is offline
Old 8th October 2009, 04:47 AM   #27
I suggested an idea in another waterproof switch thread. Get a normal small toggle (lever) switch. Then glue a lead sinker to the lever. Then a good hard bump in either direction will turn it on/off. Incredibly simple, can be used inside a totally hard pressure-proof torch casing, and uses no power when not turned on.
Mr RB is offline
Old 8th October 2009, 04:04 PM   #28
hellosir :
i m s.wajahatahmed this is my camra sonycybershot sd w-150 problem is lcd light is working plz give me easy diagram sent my e-mail.ad. s.wajahatahmed@yahoo.com i m waiting for u
syedwajahatahmed is offline
circuit, light, needed, scuba, switch
leds light up circuit needed? cestudent Electronic Projects Design/Ideas/Reviews 7 27th November 2008 09:28 PM
LED christmas light switch (what would you call a circuit like this?) Andy1845c General Electronics Chat 14 1st December 2007 04:24 PM
MC Brake Light - Circuit Help Needed I-See Electronic Projects Design/Ideas/Reviews 4 16th February 2007 03:28 AM
Traffic Light circuit design help needed? MrCrowley Electronic Projects Design/Ideas/Reviews 2 5th December 2003 07:07 AM
LIGHT CIRCUIT HELP NEEDED RON Electronic Projects Design/Ideas/Reviews 4 24th August 2003 08:56 PM
