Old 2nd July 2009, 02:20 AM   #1
Default Trying to simulate a position sensor
I'm doing a project on my car where I have a clutch position sensor that moves when the clutch throw-out arm moves. Due to some new improvements on the car I need to have the ability to bypass the sensor on occasion, yet simulate the operation has occurred to the transmission control unit. The sensor sweep is 4.75 volts to a little less than 1 volt. The modification will prevent the sensor from actually moving on certain occasions. I want to intercept the sweep signal using a relay, then reproduce it electrically to send back to the TCU. How can I reproduce a drop from 4.5 volts to about 1 volt electrically? I friend mentioned using a 555 timer, but I have no idea what the values would be to achieve these results.
agggilli is offline
Old 2nd July 2009, 03:21 PM   #2
What type of sensor is this? Is it a mechanical limit switch type sensor, is it a hall effect proximity sensor or is it something else? Also, you mentioned the sensor sweep was 4.5 - 1V. Does that mean that the sensor is outputing 4.5V normally and then it drops to 1V when the clutch throw-out arm moves or vice versa or what? What is the input voltage of the sensor? 12V, 4.5V or something else? During times when you want to bypass this sensor, how would that be done? Would you do it with a button or switch in the passenger compartment or by another method? You need to provide some more details about what it is exactly you're trying to do.
vne147 is offline
position, sensor, simulate
Flight Control Grip Movement/Position Sensor gramo Electronic Projects Design/Ideas/Reviews 5 19th May 2009 09:34 PM
Help me!How to simulate circuit with ARM 7??? Seek Micro Controllers 0 2nd March 2009 02:00 PM
please help! Need help making electric eye position sensor. Pomz23 General Electronics Chat 1 19th September 2008 02:16 AM
Sharing throttle position sensor signal rayhall General Electronics Chat 6 6th December 2007 10:29 PM
simulate inputs gastonanthony Micro Controllers 5 9th May 2005 09:47 PM
